Losmandy G11: weights to balance C14
7 replies to this topic
#1 tboss70
tboss70
  • Loc: Missouri
Posted 12 November 2012 - 08:54 PM
How many weights does it take to balance a C14 OTA on a G11?
And which ones?
#2 Mitchell Duke
Mitchell Duke
  • Loc: Georgia
Posted 12 November 2012 - 08:57 PM
On my CGE it takes 62.5 Lbs to balance it.. If you are hunting for a quick solution just buy some weights from Walmart and they work just as good.
#3 Gord
Gord
  • Loc: Toronto, ON, Canada
Posted 12 November 2012 - 09:52 PM
I have one 21(?) pound down near the bottom of the shaft, and 2 x 11 lbs sitting on an extension at the end of the shaft. That's enough for the C14 Edge.
Clear skies,
#4 tboss70
tboss70
  • Loc: Missouri
Posted 13 November 2012 - 11:44 AM
Thank you. I have one 21lb and one 7lb. Looks like I may need at least another 21lb weight if not more.
Does anyone make similar weight cheaper than the Losmandy?
$100 for a 21lb weight is a little high.
#5 Startraffic
Startraffic
  • Loc: Lat. 39.143345, Long. -77.174802
Posted 13 November 2012 - 05:35 PM
Tboss,
Weider does. You can get them at just about any sporting goods store. Sandwich a 10# between the 21# & 7# & you'll be good to go.
Clear Dark Skies
Startraffic
39.138274 -77.168898
Alt 518ft ASL
#6 Danno2006
Danno2006
  • Loc: Ontario, Canada
Posted 14 November 2012 - 10:43 PM
This setup takes 3 x 21 lbs. Before I added the top scope, I could use a Meade LXD55 weight on the end in place of the safety stop and 2 x 21lb weights part-way up the shaft.
#7 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 15 November 2012 - 08:32 AM
:D Beautiful!
#8 Danno2006
Danno2006
Posted 17 November 2012 - 09:44 PM
Thank you!
