Finder O-Rings
8 replies to this topic
#1 RAK on Tour
RAK on Tour
  • Loc: Sedalia, Missouri
Posted 14 November 2012 - 02:00 PM
Does anyone know where to get replacement O-rings for the common 6x30 finderscopes? I need to replace a broken one, and the auto parts store's O-rings are too thick.
Also, does anyone sell replacement holders that have the spring button and two adjustment screws at 90 degrees apart? Th current holder I have is the old style with three screws placed every 120 degrees.
#2 rdandrea
rdandrea
  • Loc: Colorado, USA DM59ra
Posted 14 November 2012 - 03:01 PM
Try the plumbing department at a well-stocked hardware store.
#3 coopman
coopman
  • Loc: South Louisiana
Posted 14 November 2012 - 09:38 PM
Try Agena Astro.
#4 RAK on Tour
RAK on Tour
Posted 14 November 2012 - 09:44 PM
Thanks, guys. I'm going to try Ace, Lowe's, and a local plumbing store. If I come up empty, I'll try Agena Astro. I've used them before and have been well satisfied.
#5 kfiscus
kfiscus
  • Loc: Albert Lea, MN, USA
Posted 14 November 2012 - 11:50 PM
My ACE Hardware had the correct one. Take your scope and mount with you!
#6 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 15 November 2012 - 07:12 AM
For all things hardware, McMaster Carr:
http://www.mcmaster....o-rings/=k68vhp
-Dan
#7 scott m
scott m
  • Loc: Hatfield Pa
Posted 15 November 2012 - 08:49 AM
Scope Stuff also has them http://www.scopestuff.com/ss_fring.htm
#8 RAK on Tour
RAK on Tour
Posted 16 November 2012 - 01:44 PM
I found an O-ring that works! At Ace, in the metric O-ring drawers, I found the part # ORM-204-026 at a cost of $1.39. It's a 26mm inside diameter O-ring, 2mm thick. I tried it there in the store on my 6x30 finder and it works perfectly, including fitting into the finder bracket. I tried a slightly larger inside diameter O-ring, but there wasn't enough tension to keep the O-ring in place when I tried to slip the finder bracket over the O-ring. If you have a broken or missing O-ring on your 6x30 Synta finder, this works great!
#9 hottr6
hottr6
  • Loc: 7,257', Magdalena Mtns, NM
Posted 13 December 2012 - 03:40 PM
Good to know the metric version.
I grabbed the SAE version at ACE Hardware for $0.57. It is -026 size, 1/16" width, ID=1.25", OD=1.375".
ScopeStuff and Agena Astro have o-rings for 50mm finders only.
