Collimation screws near their tips
7 replies to this topic
#1 acochran
acochran
  • Loc: So. CA
Posted 15 November 2012 - 03:18 PM
I recently had my primary mirror on my "16" Newtonian Lightbridge refigured. When I reinstalled it, I had to move the primary mirror closer to the secondary so I could use my 20mm eyepiece. I moved the primary by unscrewing the 3 collimation screws. The screws are now almost out of the mirror cell.
Last time I used the scope, about 3 hours into the viewing session, I rechecked my collimation with my Howie Glatter Laser Blug and the primary was quite a bit off--the centermark was about half an inch to the right on the Blug.
So to try to figure out why it moved so much, I just took apart the lower end of my Lightbridge. All I can see wrong is that the 3 collimation screws are near their ends (but still in the mirror cell). I'm not even sure this is why my collimation moved so much. The mirror itself may have shifted.
I can think of 2 things that might help, get longer screws or maybe get a low profile focuser. I got my screws+springs from Farpoint. Maybe I will e-mail them.
#2 catboat
catboat
  • Loc: Maine
Posted 15 November 2012 - 05:06 PM
Not good to have the collimation screws extended so far. And longer screws may encourage movement/flex.
Can you remount your tailgate/cell assembly farther forward -- drilling fresh holes for the attachment screws? Better yet might be to shorten the truss poles.
#3 Jon Isaacs
Posted 15 November 2012 - 09:12 PM
The further forward the mirror, the lower the force the springs exert. Longer bolts with washers under the springs to shim them might solve the problem.
#4 panhard
panhard
    It's All Good
  • Loc: Markham Ontario Canada
Posted 15 November 2012 - 09:59 PM
Jon is on the right track.
#5 acochran
acochran
  • Loc: So. CA
Posted 16 November 2012 - 02:43 PM
Thanks Jon, that's a good idea! I went ahead and put 5 washers under each spring to compress them more. We'll see if that helps.
I checked with Bob's Knobs and he did not carry knobs with threaded rods longer than 2 inches. He referred me to a company called McMaster-Carr (www.mcmaster.com). They have knobs with 3 inch long threaded rods, so I ordered 3. I will shorten them a little with a hacksaw when they get here.
#6 okieav8r
okieav8r
    I'd rather be flying!
  • Loc: Oklahoma!
Posted 16 November 2012 - 04:37 PM
Before you cut those rods with a hacksaw, be sure to run a nut down the threads inside of where you will cut first. Then after you cut the rods, running the nut down to where you cut the rod will condition the threads on the end of the rod where you cut it. Sometimes, cutting a threaded rod will damage the threads just enough that it's hard to thread a nut back onto it. Not always, but it's caused problems for me a few times.
#7 acochran
acochran
  • Loc: So. CA
Posted 01 December 2012 - 06:17 PM
FYI: Lightbridge 16" collimation screws are metric. Longer than 2 inches, I had to make my own screws with metric threaded rods, hacksawed to proper length and metric handles that were bought online (All Metric Small Parts). I epoxy glued handles onto rods.
When the clouds go away, we'll test them.
#8 saxmaneagle
saxmaneagle
  • Loc: Saint Francis, MN
Posted 05 December 2012 - 06:07 PM
I used a small file, and rounded the tips of my screws, (where they touch the secondary). I found that the thread ends on them caused little 'jumps' when the last bit of adjustment was done. This seemed to make the adjustments much smoother, and more accurate.
