Siebert 24 EP's or ES 24-68's in Black Night BV's?
15 replies to this topic
#1 bhuloka
bhuloka
  • Loc: Maryland, USA
Posted 16 November 2012 - 08:38 AM
I just ordered Siebert Black Night 25mm CA as my very first binoviewers. Which of these two eyepieces will perform best?
I know a lot of people like the ES 24-68's. But Siebert's 24-65's are cheaper, and probably lighter. I'll be using them with the 1.3x-2x-2.7x multimag corrector, on my 16" f/4.5 dob.
I'm really looking forward to my first ever look through a binoviewer, based on what I've read here on CN. :D
Lawson
#2 dakota
dakota
  • Loc: SD (God's Country)
Posted 16 November 2012 - 10:07 AM
I have never look thru the ES-24's but I do have a pair of Siebert 24's which I use in my Supercharged WO binoviewer and I can attest that they are very good eyepieces.
#3 bhuloka
bhuloka
Posted 16 November 2012 - 10:19 AM
Hans, it seems that your scopes are f/8 or more?
On Seibert's website, he says that his 24's best above f/7.
He also says they are great for binoviewers. So I'm wondering if my f/4.5 dob will be too much for those EP's. Maybe the ES 24's will be a better performer?
#4 denis0007dl
denis0007dl
    Vendor (Binoviewer Supercharging)
  • Loc: Umag, Croatia
Posted 16 November 2012 - 11:20 AM
My ES 24 68" percorms extremly well in my MkV binos at f/5, and dont know about Sieberts units!
#5 dakota
dakota
Posted 16 November 2012 - 11:31 AM
Ask Harry. He will be upfront with you.
#6 killdabuddha
killdabuddha
Posted 16 November 2012 - 12:21 PM
When we were speakin with him, he sounded genuinely discouraged that we'd gone with the Aspherics rather than with his, in an objective way rather than bein personally disappointed. Sorry I can't give you a definitive comparo, except to say that the ES 24mm 68s are our hands-down favorite for our mag 4.5 skies. Eye relief, comfort and view are superb. Of course they're heavier--maybe double Harry's weights--and we're at f/6. Am certain his are good, but we couldn't pass up the ES and Aspheric hype. Too bad that, by sheer number, Harry's comparisons are probly receivin short shrift.
#7 winterprillan
winterprillan
Posted 16 November 2012 - 01:11 PM
I got the 24 pans in my denk II and i like them. But after reading a review called "24-26 mm Eyepiece Comparison" by William Paolini, i have concidered to buy the ES24. Do you think the ES24 would perform better in a F3,6 dob? Or will the pans be better for that fast focalratio?
#8 killdabuddha
killdabuddha
Posted 16 November 2012 - 02:21 PM
Don't recall the focal ratios he was testin under, but that shootout convinced us, especially since Bill gave the nod to the ES over his own Pan. But 3.6? Wow.
#9 winterprillan
winterprillan
Posted 16 November 2012 - 06:28 PM
what i can see the es24 barrel are wider than the pans. are you having any problem with nose space when binoviewing? my ipd is 58mm.
#10 denis0007dl
denis0007dl
Posted 17 November 2012 - 01:03 PM
I have fat nose, and dont have nose space problem :)
#11 bhuloka
bhuloka
Posted 17 November 2012 - 07:35 PM
Has anyone actually tried the Siebert ultra 24's in their binos?
Or even seen a pair? I'm thinking to cancel my Siebert 24 order, and get the ES 24-68*s instead.
#12 avenger
avenger
  • Loc: USA
Posted 17 November 2012 - 09:14 PM
I have a set of Siebert 24's and in my 6" f/6.5 Refractor, the Siebert 24's are sharper then the ES24's and the contrast is also in favor of the Siebert's. I think it is do to Harry using a 3 element design. I have tried the 24 Ultra's in a 16" f/4 Newt, and the Ultra's are very sharp on axis. They are sharp out to 90% of the field in the 16" f/4 used without a bino, and sharp across the fild when used with the bino. The pic shows the 24mm Ultra's with the 9.9mm and 12.4mm Siebert SSS orthos.
#13 bhuloka
bhuloka
Posted 19 November 2012 - 12:15 PM
Thanks, Avenger. That's pretty much what I needed to hear.
On Siebert's website, he says that the ultra 24's are especially optimized for binoviewing using an optical corrector, but not good for monoviewing below f/7. That made me wonder about their quality. But, from your real world experience, I see that even for monoviewing, they are pretty good, and for Binoviewing, superior to the ES 24's.
I especially like the fact that they are very lightweight, compared to the ES's, which are 11.2 ounces each. I think my dob will balance much better with the lighter EP's in the binos, so that is a very important consideration, as well. Sharp and contrasty to the edge is just fine with me, too. The Siebert's are also cheaper than the ES's. I also really like the attention to mechanical useability in Siebert's designs; diopters, short optical path, light weight, eye relief, barrel shape, etc.
#14 killdabuddha
killdabuddha
Posted 19 November 2012 - 12:31 PM
No way you'll be disappointed. Harry just makes good stuff. Period. Good for you. (We went with ES cuz we're flyin uncorrected.)
#15 winterprillan
winterprillan
Posted 19 November 2012 - 01:28 PM
I Just sent a order for two Siebert ultras 24mm. I Shoosed them over the es24 because i just think they are better.
#16 gcfboulder
gcfboulder
  • Loc: CO
Posted 20 November 2012 - 12:25 AM
I've got a 12.5" F6 Dob, which is not really a fast scope, but the Siebert Ultra 24's in combo with the Blacknight BV work great. I too have the 1.3/2/2.7 OCA. On top of that, I purchased an extra piece from Harry which gives me 1.0 mag with the OCA, to give me even more versatility. This is the setup I use at dark sky sites, and it does not disappoint.
At home, I tend to use my C8 instead because I just like using a mount that tracks at home. Siebert's system works great with that scope, too. I don't need an OCA with the C8, but use Siebert's Galaxy View .6 focal reducer when I want a wider field of view. And I have a screw in adapter which turns the focal reducer into a 1.5 barlow!
The point is, it's very easy to call up Harry and ask for an additional part that enhancers your system, and to get it for a reasonable price. That's why I picked his system, even though I really didn't know in advance if it would be as good as a Denk or Baader.
Everything I've purchased from Harry has worked well. I have no regrets about not buying a Denk or Baader, etc. although I have nothing bad to say about those systems.
