DSLR and filters
9 replies to this topic
#1 Pistorbanic
Pistorbanic
  • Loc: Ohio, USA
Posted 16 November 2012 - 11:10 PM
Hello.
I use a Cannon DSLR attached to my reflector scope where the eyepiece would go(Prime Focus?). If I want to use filters while snapping pics, what type do I use? I can't use an eyepiece filter because I'm not using an eyepiece.
Confused.
#2 NeilMac
NeilMac
  • Loc: MedHat, AB, Canada
Posted 17 November 2012 - 12:05 AM
The Adaptor has threads inside ?
#3 Pistorbanic
Pistorbanic
  • Loc: Ohio, USA
Posted 17 November 2012 - 12:09 AM
It doesn't. Just checked.
#4 guyroch
guyroch
    Vendor (BackyardEOS)
  • Loc: Under the clouds!
Posted 17 November 2012 - 12:45 AM
You can use an eos clip in filter. These filters are mounted in the body cavity.
Guylain
#5 TopherTheME
TopherTheME
  • Loc: Rochester, MI
Posted 17 November 2012 - 10:26 AM
I use an Orion field flattener on my scope which doesn't have threads for filters. To get around this I flocked the inside of the focuser barrel so I can slide in an eyepiece barrel and it wills stay put. This way I can mount filters on eyepiece barrels (without actual eyepiece of course) and just slide them in in front of the field flattener.
#6 bouffetout
bouffetout
  • Loc: Canada
Posted 28 November 2012 - 03:46 PM
I use Astronomik CLS clip-in filter...google it ,it's good quality stuff !
#7 mmalik
mmalik
    DSLR camera modifications
  • Loc: USA
Posted 28 November 2012 - 03:48 PM
This... is what I use. Thx
#8 Phil Wheeler
Phil Wheeler
  • Loc: 3 miles WNW of Celestron
Posted 30 November 2012 - 12:14 PM
Is that a plain nose piece or a reducer-flattener on your 60Da?
#9 jsines
jsines
  • Loc: Berkley. Michigan
Posted 30 November 2012 - 01:28 PM
How is your dslr going into the eyepiece holder? I'm assuming you're using a t-adapter, and the t-adapter is held in the eyepiece holder? I use a t-adapter that has rings on the inside so I can use filters attached to the t-adapter. I have an Orion SkyGlow filter that is always attached to my t-adapter, which then attaches into the scope eyepiece holder.
#10 mmalik
mmalik
  • Loc: USA
Posted 30 November 2012 - 04:50 PM
Just the plain nose piece. Thx
