Who invented the barrel safety undercut?
69 replies to this topic
#1 5u4
5u4
  • Loc: FL
Posted 18 November 2012 - 04:25 PM
Wondering if anyone knows the origin of this ignoramus feature & why the vast majority of eyepieces available today come with it.
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 18 November 2012 - 04:35 PM
I don't know, but... :ranting:
Clear skies!
Thomas, Denmark
#3 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 18 November 2012 - 06:26 PM
I'm guessing some time in the late '80s because my earlier eyepieces definitely didn't have the groove.
Many of my eyepieces from the '90s didn't either, so it's only become fairly universal since 2000.
#4 Loren Toole
Loren Toole
  • Loc: New Mexico USA
Posted 18 November 2012 - 06:27 PM
I've been reluctantly participating in this sales gimmick since it first appeared in the late 90s.... to the best of my knowledge, Televue was the first. Obviously this was an "innovation" at the time, but poorly considered since it also appeared when setscrews were being replaced by compression rings.
I believe it was the heavy Panoptics and Naglers that justified this extra safety feature...
#5 herrointment
herrointment
  • Loc: North of 64
Posted 18 November 2012 - 06:31 PM
I can't think of one EP I own that is easily removed from the diagonal.
Is there not a fortune to be made in replacement barrels?
No there is not. I do wish someone would try just for the ____ of it.
#6 Pollux556
Pollux556
Posted 18 November 2012 - 06:35 PM
Thanks to this invention ! May be my 20mm Nagler T2 would not have been in such good condition. :bow:
#7 Scanning4Comets
Scanning4Comets
    Markus
  • Loc: Canada
Posted 18 November 2012 - 06:41 PM
I hate this invention too. Eyepieces used to get hung up on my compression ring when I did have the ones with the safety undercut on them, but I have none because I use Antares Twist lock adapters on all of my 1.25" eyepieces and the 2" eyepieces I do have do NOT have the safety undercut on them.
I have two extension tubes that have this on them and I have tape in there wound right up until the undercut is GONE.
I steer clear of them.
However, if I used a diagonal and an EQ scope where the configurations of my scope move a lot, the safety undercut would be good to have in case one of the eyepieces were loose in the diagonal.
#8 jgraham
jgraham
Posted 18 November 2012 - 07:35 PM
Grrrrr, I hate that darned 'feature'. I just dropped a set screw in the grass trying to get my eyepiece out! In some cases I've filled it in with aluminized tape.
#9 ibase
ibase
  • Loc: Manila, Philippines 121°E 14°N
Posted 18 November 2012 - 07:46 PM
At one time it saved my Nagler 5T6 from falling onto hard concrete so I can't say that am hating 'em.
Best,
#10 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 18 November 2012 - 07:48 PM
Do we really need safety undercuts in eyepieces to keep them from falling out? There's little chance of that happening with my Dobs. The focusers are all slanted upwards at about 45 degrees or so. Unless the eyepieces jump up and out of the focuser on their own, they aren't coming out until I take them out. I only see that this "improvement" would make sense for refractors and SCTs and Maks. The focuser in those are at the wrong end of the tube!
I can say this. I have some of those scopes.
:grin:
Diagonal? Isn't that just another name for the secondary mirror? :grin:
#11 herrointment
herrointment
  • Loc: North of 64
Posted 18 November 2012 - 08:12 PM
I DO have one EP that was easily removed from the holder thingy.
Never put it back after one look. It has a new job in the workshop....
#12 Starman1
Starman1
  • Loc: Los Angeles
Posted 18 November 2012 - 08:16 PM
:roflmao:
#13 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 18 November 2012 - 09:45 PM
Clear skies!
Thomas, Denmark
Definitely a solution in desperate search of a problem.
#14 iluxo
iluxo
Posted 18 November 2012 - 10:52 PM
Thankfully my Vixen e.p.'s don't have this.
Unfortunately both my TMB ones do and its a major nuisance.
#15 Ed Kessler
Ed Kessler
  • Loc: Millersburg, PA
Posted 18 November 2012 - 11:14 PM
Brandons don't have the undercut!!! :step:
#16 davidpitre
davidpitre
  • Loc: Central Texas
Posted 18 November 2012 - 11:26 PM
When I am struggling to pull my $800. Ethos out of my $500. Paracorr I frequently think " Really? Is it necessary that I put up with this? This is the best you can do?"
#17 GeneT
GeneT
    Ely Kid
  • Loc: South Texas
Posted 19 November 2012 - 12:35 AM
This is a situation where some eyepiece makers insist on forcing a design element that most users would rather not have.
#18 Mike B
Mike B
    Starstruck
  • Loc: shake, rattle, & roll, CA
Posted 19 November 2012 - 12:58 AM
Wasn't that first developed by Mr. Safety, the TeleVue designer guy before Mr. Dellechiaie?
:whistle:
Yeah, i can envision where a Mak or 'fractor with a "secondary" mirror at the aft-end could suddenly loosen & twist 180-degrees with a glass grenade inserted, spilling the big guy onto the pavement or dirt. Yet how many instances of an expensive EP slipping from gloved fingers while suddenly hanging up by the dreaded undercut, and thence toppling from the focuser? :4
Instead, Mr. Safety, how about a short lanyard, fastened with some fancy schmancy proprietary system to the focuser, with a safety clip hooked at the EP? You could use the flange screw supplied with so many green-lettered EPs. :smirk:... or the hole it disappears from. I've actually done that with a pair of 12T4 Naglers in my BVer.
Otherwise, i have no use for safety undercuts.
:vomit:
#19 cjc
cjc
  • Loc: Northern Devon, England
Posted 19 November 2012 - 04:08 AM
Thin shallow grooves on well fitting barrels would be worthwhile to me, if only they were standardised. However in practice undercuts range in depth from a sensible 0.2mm (Vixen NPL, Antares Ortho), to a ludicrous 0.6mm (TMB Planetary and ES), with the dimensions and profile of the undercut area also varying widely. Barrel sizes also vary with the Antares Ortho being an interference fit at 31.7mm compared with my 24mm ES68 which is significantly undersized at 31.4mm. The variations are such that when coupled with the misnamed compression ring, it is hardly surprising that there are problems.
#20 Jon Isaacs
Posted 19 November 2012 - 05:14 AM
Personally I like eyepieces with undercuts...
There are a few combinations that can result in an eyepiece getting hung up, the TMB Planetary's and the William Optics 2inch-1.25 inch do not always mate and it takes a bit of rock to get them free but in general they work just fine... Never have a problem with the TeleVue adapters or focusers/Paracorrs.
I do appreciate them with viewing with my 12.5 inch F/6 equatorial because sometimes the focuser is pointing down and the undercut adds a bit security, an eyepiece falling 5 or 6 feet and hitting concrete is worth avoiding.
#21 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 19 November 2012 - 09:14 AM
While I don't have many kind things to say about the hated "safety" undercut (which functions much more like a product defect), in all fairness the tapered iteration as seen on the new Delos is somewhat better in terms of snagging on my AP MaxBrite. I have yet to test it in my Moonlight focuser.
But all things considered, in my estimation I have much more risk of being involved in a car accident that damages my astro gear than risk of dropping an eyepiece. But I still accept the risk of driving to the dark sites and the higher risk of returning home fatigued on twisty mountain roads with deer popping out everywhere.
I would be happy to accept the remote risk of smooth side eyepieces to restore 100% function reliability in my focusers and star diagonals.
#22 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 19 November 2012 - 09:45 AM
Like Howard missing gravity on the Big Bang Theory I miss pulling out an eyepiece nice and smoooooth outa the focuser with NO hangups....
http://www.youtube.c...feature=related
#23 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 19 November 2012 - 10:53 AM
Just bought new 1.25" adapters with the collar instead of just the set screws; but even these took a few "in and out" with the eyepieces before they started going "in and out" without catching.
#24 Mike B
Mike B
    Starstruck
Posted 19 November 2012 - 11:48 AM
Jon, do you find that standard sandstone does the trick, or does it require something like granite to get them out?
:poke:
#25 dscarpa
dscarpa
  • Loc: San Diego Ca.
Posted 19 November 2012 - 12:23 PM
My newer TVs with the tappered undercut and similar ones on other eyepieces rarely get hung up. Ditto for very shallow ones near the top of the barrel like my XWs have. The worst are my 2 Meade 5000 UWAs and older style Ethos 13's 2" barrel and Nagler 22 all with deep undercuts. My preference would be smooth long barrels but the better undercuts are ok. David
