My just completed Jaegers 6-inch f/10
60 replies to this topic
#26 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 19 November 2012 - 11:20 AM
Oh! The Hastings tube was not bad, especially for the price. There's one small ding in the main tube, which nearly went away with the powder-coating. I did have to sand the ends a bit to get rid of the rough edges, but it was quite square, which had been a worry. Some lines also show (barely) along the tube, where the manufacturing (and more of my sanding) did not quite make it smooth. I'm almost glad it isn't perfect; this way, maybe I won't be quite as insane in how careful I am with it!
#27 dan_h
dan_h
Posted 19 November 2012 - 11:46 AM
It's a great looking scope. Nicely done!
dan
#28 tim53
tim53
  • Loc: Highland Park, CA
Posted 19 November 2012 - 12:53 PM
Beautiful paint job and overall nice job! I also like the handle/finder mounts made out of aluminum square tubing. Great idea!
JimC
I was going to say exactly the same thing. I really like how that turned out! What an elegant way to turn a rather spartan, even ugly square tube into something attractive while still being very functional! Gives me some ideas... ...like how about putting hardwood inserts inside the tube, fer instance!
Love the red tube, too!
-Tim.
#29 rboe
rboe
  • Loc: Phx, AZ
Posted 19 November 2012 - 01:02 PM
Wow! :jawdrop: That turned out nice!
Is the 127mm lense? What size tubing did you buy for the dew sheild?
#30 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 19 November 2012 - 01:30 PM
I like the idea of hardwood inserts, and will give that some thought. However, the opening in the handle actually seems to work as a rough finder; sort of a very poor man's Telrad. I plan to buy a G-11 to put this on, and I tend to push to objects. I want to see if I'm right about rough alignment with the handle (skies are supposed to clear tomorrow).
The tubing for the shield is 8-inch; the main tube is 7-inch, for the 6-inch lens. Dan Crawford originally thought he'd be able to make the cell take a 7-inch dew shield, but later wrote to say that 7.5-inches was the smallest he could get it. In the meantime, I had ordered and started finishing a 7-inch shield. I've attached a photo. If someone wants it, I'd be glad to pack it up and send it for the shipping cost. It's a 7-inch outer diameter pipe, with a .060 inch thick wall; nine inches long. Unpainted inside and out, but sanded with 320 grit. The cap was also made to use the solar filters I made for my 5-inch scopes. The photo doesn't show it, but the cap is made from a thin ring of birch plywood, with a thinner piece glued on the front.
#31 tim53
tim53
Posted 19 November 2012 - 01:58 PM
This reminds me of another idea I had for a zero-power finder. And it might work in this case, too. I make a lot of my tubes out of plywood, so they're polygonal. Even with just a semi-gloss polyurethane on them, I can sight along the tube and line up on a bright star or planet by getting its reflection to converge with the sky view. So, you could probably do the same with your square tubing, even if you were to put inserts on the inside, by sighting along the outside faces.
-Tim.
#32 tim53
tim53
Posted 19 November 2012 - 02:01 PM
I should note that this worked so well with my 12.5" f/23 Cassegrain that it was more than a year before I put a finder on it. Just sighting along the tube sides was enough to get the object in the field of view of a 28mm RKE at the Cass focus (the telrad in this pic was added later):
-Tim.
  • Bomber Bob likes this
#33 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 19 November 2012 - 02:04 PM
Great idea, Tim. Thanks!
#34 Rutilus
Rutilus
Posted 19 November 2012 - 03:13 PM
Great refractor build.
#35 mikey cee
mikey cee
  • Loc: bellevue ne.
Posted 19 November 2012 - 05:20 PM
Paul a red finder will put the cherry on top of this bad boy|! :bow: Nicely done! :D Mike
#36 rboe
rboe
  • Loc: Phx, AZ
Posted 19 November 2012 - 06:38 PM
I keep reading and misreading your dew shield post. :p I think I can make use of the 7" dew shield if you have not gotten rid of it yet. PM for details.
#37 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 19 November 2012 - 09:25 PM
Thanks once more for all the nice words!
And, Ron, I just sent you a PM.
#38 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 19 November 2012 - 09:31 PM
I've built several other scopes, but they were all of the just-so-it-works style. Nothing very handsome. This one looks nice enough that my next project will be to build a well-padded, solid case for it. With wheels on one end. (The scope is pretty massive and unwieldy.)
#39 rboe
rboe
  • Loc: Phx, AZ
Posted 19 November 2012 - 11:25 PM
The 5" aint' light either.
#40 Dave O
Dave O
  • Loc: Sri Lanka
Posted 20 November 2012 - 12:24 AM
Stunning! Absolutely beautiful. Thanks for sharing.
#41 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 20 November 2012 - 10:38 AM
Thanks, Dave!
#42 Project Galileo
Project Galileo
  • Loc: Jefferson County, Colorado
Posted 20 November 2012 - 12:22 PM
Great work, fine craftsmanship, and an excellent result. Enjoy!
#43 Anil
Anil
  • Loc: Bangalore, India
Posted 21 November 2012 - 02:14 AM
Awesome looking scope, love the color, great work. Cradle design is a beauty!
#44 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 21 November 2012 - 01:40 PM
Thanks again for the comments!
I went out today and bought the materials for a case to hold it, and will hope that the clear skies that have been forecast for three days will actually happen soon.
#45 rwiederrich
rwiederrich
    Goldfinger
  • Loc: Gorst Washington(center of the Universe)
Posted 21 November 2012 - 04:52 PM
Great job Paul....I love homemade refractors..my specialty.
Again..awesome job.. :bow: :bow:
Rob
#46 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 21 November 2012 - 08:01 PM
I just set the scope up and took a look at the moon. I'm no optics expert, but all looked great to me. Especially since the seeing was not good, and lots of wispy clouds got in the way. I'm going out in a couple of hours to look at Jupiter. I have a friend whose got experience collimating refractors, and he's going to come help me check that. I might as well get the best out of it that I can.
#47 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 22 November 2012 - 09:42 AM
Thanks, Rob!
#48 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 01 December 2012 - 05:53 PM
I've made a sturdy but ugly case for it.
  • terraclarke, mitsos68 and Bomber Bob like this
#49 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 01 December 2012 - 06:02 PM
It has a handle on top, and another in the front. I put casters in the rear so that I can roll it to where I want it. Between the long case itself and the scope, this has to weigh about 50 pounds. It has found a place near the front door for now, and wants to go outside.
I also bought a new diagonal for it. I only had a cheap one from the Surplus Shed. When I tested it using the cheap diagonal, views became mushy by 200x. I only had a short time of clear skies, so could not raise the tripod and use it straight through. I'm hoping the new diagonal will allow me to go higher. I guess it could have been the seeing. It also might need collimation.
Another question is whether the tape spacers that came with it from the Shed are the right thickness. Can anyone point me to information on just how thick the spacing should be? I don't want to mess with it if I don't need to.
Of course, I could also have bought a lens that is just not that great. I hope not, and will assume not, for now.
  • mitsos68 likes this
#50 PaulEK
PaulEK
  • Loc: Wisconsin
Posted 09 June 2015 - 01:24 PM
I referred to this old thread in another post earlier today, and went through it again. I see that I never came back to update my last comment about the views through it. I had a friend help me collimate it (both the focuser and the lens) and it really helped. I was very happy with what I saw of the moon and Jupiter, but still wondered if it could get a tiny bit better. It needs further testing, and possibly some adjustment of the elements, but seeing is usually so bad here that I haven't gotten around to it.
It's not my most used scope because it is pretty unwieldy. It's also so nice that I don't want to damage it. I often do my viewing while doing public outreach, and this scope usually stays home. I'm working with my school district to build a school/public observatory, which should be finished this summer. This is one of the scopes I'm donating to it, so it will soon be getting plenty of use!
  • terraclarke and Bomber Bob like this
