Jupiter f25 11/20/12 More Good Seeing
22 replies to this topic
#1 sfugardi
sfugardi
  • Loc: CT
Posted 20 November 2012 - 03:04 AM
I was lucky to catch a small pocket of good seeing and transparency just as Jupiter peaked in the sky facing the GRS this morning just after 1am. Best 2000 frame stacks combined in WinJupos using R as the Lum cranked to 149% gamma to help brighten the image with minimal burning. 80fps 60s RG, 45fps 75s B, histograms 65%, gain 2650-2800, resized 125%
Steve
#2 Freddy WILLEMS
Freddy WILLEMS
  • Loc: Hawaii, Honolulu
Posted 20 November 2012 - 03:30 AM
Aaahhh Great seeing attacks !!
#3 sfugardi
sfugardi
  • Loc: CT
Posted 20 November 2012 - 06:07 AM
Freddy, It's crazy how you can going over a month with poor conditions, then good seeing attacks on multiple nights. Here's an a version with no resizing and some noise reduction applied, after 2hrs of sleep...
Steve
#4 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 20 November 2012 - 09:30 AM
Steve,
Superb! One of your best. Congratulations!
Paul
#5 sfugardi
sfugardi
  • Loc: CT
Posted 20 November 2012 - 10:26 AM
Paul, Thanks! And I can thank a boring Monday football game to push me off the couch and get some Jupiter data. The CSC had a small 1 hr window of good seeing and transparency which I caught. As I packed up the clouds were rolling in. This may be about as good my old scope can capture. I've been lucky with the seeing this week, and I hope you get a couple perfect nights during opposition. Take it easy
Steve
#6 BKBrown
BKBrown
  • Loc: Northern Virginia, USA
Posted 20 November 2012 - 10:44 AM
Super work Steve, glad you are getting some good seeing conditions! And there's nothing to complain about with our C11s, they are fine imaging scopes...
Clear Skies,
Brian :waytogo:
#7 Eddgie
Eddgie
Posted 20 November 2012 - 10:55 AM
Ah, perfect. Color saturation is fantastic. Just the right level of paleness.
Love it.
#8 ToxMan
ToxMan
  • Loc: Tucson, Arizona, USA
Posted 20 November 2012 - 11:10 AM
These are great! Hope the great seeing continues.
#9 edsplace
edsplace
Posted 20 November 2012 - 11:16 AM
Great image, the flea3 and c11 combo strikes again.
#10 AstroDan2015
AstroDan2015
  • Loc: Racine, Wisconsin
Posted 20 November 2012 - 12:38 PM
Hi Steve,
Sweet image indeed, congrats!!
Regards, Dan :)
#11 sfugardi
sfugardi
  • Loc: CT
Posted 20 November 2012 - 02:45 PM
Guys, Thanks for the positive feedback! CSC predicted good seeing and weather.com predicted partly cloudy. Maybe the weather channel needs to link into the CSC... Since I am not used to decent Jupiter data, my old processing methods seem harsh, so I went back 1 last time and decided to only derotate and combine RGB in WinJupos (not L) with a 10% gamma boost each channel, then perform a color alignment/RBG balance in Registax6. The max brightness is only 192 but the result is smoother with a more realistic color and that can be repeated vs the random eyeball test.
Steve
#12 rik ter horst
rik ter horst
  • Loc: Zuidwolde, the Netherlands
Posted 20 November 2012 - 02:54 PM
Steve, that's a beauty! It's sharp! Good that you provide all relevant information at the bottom of the image!
Cheers, Rik
#13 lcd1080
lcd1080
  • Loc: Maryland, USA
Posted 20 November 2012 - 02:56 PM
That looks marvelous Steve, you've always been one of the people I look up to for setting the standard on how well a C11 can capture Jupiter. Of the 3 planets, Mars, Jupiter and Saturn, I believe that Jupiter is the most difficult to render. In addition I love the way you quantify the parameters used to acquire and process planetary images. That offers a great deal of practical help to others in fine tuning the process.
Pete
#14 sfugardi
sfugardi
  • Loc: CT
Posted 20 November 2012 - 03:39 PM
Rik, Pete, I really appreciate your compliments. To avoid reinventing the wheel each time, I wrote down exactly what I did to get this image and it will be my standard Jupiter processing from now on.
Flea3 + Astronomik RGB filters + Fire capture
All Gains=2700+/-100, Histograms 60-65%, 400x400 ROI
R: 80fps, 60sec >> determine best focus for R, then use excel spreadsheet for G=R+20 & B=R-29 offsets
G: 80fps, 60sec
B: 45fps, 75sec
Castrate avi videos
AS2! force global 2, best 2000 frames, 60% normalize, 1.5x drizzle, approx 15APs
Sharpen in Reg6, all using initial layer=2 (keep totals the same for each channel, just a theory)
R: Slider2, 100
G: Slider2, 100
B: Slider2, 50, Slider3, 50
Winjupos, image measurement default settings (P=direction of rotation) using average avi time
combine derotated RGB frames 1.1x gamma each
Clean up background noise in PS
Reg6 for RGB auto color balance & resize Lanzcos back to original image dimension
PS to increase black canvas size & apply a slight linear contrast curve with the midpoint 50% of max (do not use PS default, make your own)
Add FireCapture frame
Comments and improvements are always welcome. I know Emil says that pre-castrating is waste of time, but I've always done it and it's a nice way to keep the final avi on disk.
Steve
#15 sfugardi
sfugardi
  • Loc: CT
Posted 21 November 2012 - 09:54 AM
Here's 1 last image from this set taken, using L-RGB in WinJupos with the L=R but 50% less sharpened in Reg6, Gammas for RGB 1.49, L is default 1.00. Color aligned in Reg6. LRGB does seem to show more detail vs RGB, provided the amount of L contrast is used sparingly.
Steve
#16 moxican
moxican
  • Loc: Toronto, ON
Posted 21 November 2012 - 10:46 AM
I like the third one best. But that's just personal taste. Very nice job though.
What do you use to frame it so nice with info and stuff? And how?
#17 Kokatha man
Kokatha man
Posted 21 November 2012 - 11:28 AM
You've grabbed some real beauties there Steve - congratulations mate....! :waytogo: :waytogo: :waytogo:
#18 ToxMan
ToxMan
Posted 21 November 2012 - 11:46 AM
The processing change really improved what were already great images. You nailed it, Steve.
#19 sfugardi
sfugardi
  • Loc: CT
Posted 21 November 2012 - 02:42 PM
moxican, Thanks! The framing is done automatically with FireCapture, which you will need to download the freeware,http://firecapture.wonderplanets.de/screenshot.html. Once you open FC, click on "dummy cam", then the square folder icon to get to the session browser. You will need to save your final image as a .jpg before trying to input to the FC web framer. If you don't use FC to capture the data, you will have to enter everything manually, but the final presented image will look the same.
mo, Thanks! I'm moving my data off my laptop to make room. Tonight I'll try my 1.8x or 2x barlow with an extension combo to boost the mag to f26 or f27 and will post if the data is good.
toxman, Thanks! I suspect that sharpening 100% in Registax per channel, with no LR deconvolutions sounds crazy, but it seems to work.
Steve
#20 rg55
rg55
  • Loc: western US
Posted 21 November 2012 - 02:59 PM
Suitable for framing! I can see these gracing the walls of a planetarium.
#21 HANTO
HANTO
  • Loc: Unterallgaeu, Bavaria, Germany
Posted 21 November 2012 - 03:06 PM
Lovely images, Steve!
Regards
Torsten
#22 Jason H.
Jason H.
  • Loc: Central Florida
Posted 21 November 2012 - 06:35 PM
WOW STEVE!!!!!
NICE GOING!!!!!
Jason W. Higley
#23 moxican
moxican
  • Loc: Toronto, ON
Posted 21 November 2012 - 07:06 PM
Thanks Steve
