BAMBI vs. GODZILLA - new Skywatcher 300PDS
13 replies to this topic
#1 eyepiecedropper
eyepiecedropper
  • Loc: aschaffenburg, germany
Posted 20 November 2012 - 02:44 PM
Hi, this is Bambi vs. Godzilla ;-) Pics just can´t show you how big this 12" is. It looks pretty much like an oil drum. The mirror + holder alone is heavier than Bambi, an 8" f/6 scope. I´m not sure anymore that I want to mount this heavy thing on my eq-6. It seems this time I´ve gone too far. But I like it (her? him?) already. This thing on my little balcony is a challenge for sure.
BTW: the PDS has a welded tube, not a seamed one.
regards, Martin
#2 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 20 November 2012 - 03:15 PM
Truthfully, it wasn't even a contest......... :lol:
#3 Deep13
Deep13
  • Loc: NE Ohio
Posted 20 November 2012 - 03:35 PM
I see you have rings on the 12". Which mount do you use?
#4 DavidC
DavidC
  • Loc: Mesa, Arizona
Posted 20 November 2012 - 06:03 PM
Nice telescope, that looks impressive! You mentioned that you weren't sure if you wanted to put your scope back onto an eq-6. What about making altitude bearings and a Dob mount? That could be an easier option. What is the f/ number on it?
David
#5 Deep13
Deep13
  • Loc: NE Ohio
Posted 20 November 2012 - 08:57 PM
My 8" f/6 sonotube scope (9.5" overall diameter) is about the limit for my EQ6. A 12" will be too much for it.
#6 eyepiecedropper
eyepiecedropper
Posted 21 November 2012 - 04:38 AM
hi all + thanks for your replies.
the 300 pds has a focal ratio of f/5. i will give it a try and mount it on my eq-6. therefore i´ve ordered a losmandy saddle. the pds was delivered with a nice losmandy plate.
btw the sonotube 8"f/6. rides quite nicely on my eq-5. total weight is 10 kgs with tube rings. it has a very nice and smooth kineoptics hc-1 focuser.
regards, martin
#7 eyepiecedropper
eyepiecedropper
Posted 23 November 2012 - 05:51 AM
setup on eq-6 without mirror assembly. the silver thingy under the ota is the first of the tube liners i will put -inside- the tube. the liner is made from 4mm styrofoam to get rid of the thermal mass of the steel tube. i´ll glue in old wiper blades inside on the other side of the drawtube as secondary baffles. vignetting is no problem since i will use this scope only for visual planetary observation.
even without the mirror this thing is very heavy to put it on the mount with one person.
regards, martin
#8 eyepiecedropper
eyepiecedropper
Posted 23 November 2012 - 05:54 AM
the skywatcher 3" dovetail plate that came with the ota.
#9 Deep13
Deep13
  • Loc: NE Ohio
Posted 23 November 2012 - 06:52 PM
Huh. Where did you get that short peer and feet for the EQ6?
#10 eyepiecedropper
eyepiecedropper
Posted 24 November 2012 - 01:30 PM
it works!
for visual it works better than i thought. focussing is not so bad with the fine focusser. dampening time is about 2 seconds.
this is a shortened skywatcher pier/tripod. shortening the pier as low as possible makes life a lot easier.
#11 eyepiecedropper
eyepiecedropper
Posted 24 November 2012 - 01:33 PM
i used folded flocking paper for the secondary baffles. easy and stable.
#12 dvb
dvb
    different Syndrome.
  • Loc: Vancouver, Canada
Posted 26 November 2012 - 03:15 PM
Impressive!
I had the 10" (254 mm) Skywatcher. Tricked out with rotating rings it was 45 lb. (20 kg). A Skywatcher EQ6 Pro handled it impressively.
I'm sure the 12" (300 mm) Skywatcher OTA weighs significantly more than the 254mm- but I wouldn't count the EQ6 out, especially if you can keep the weight of accessories down.
#13 eyepiecedropper
eyepiecedropper
Posted 27 November 2012 - 12:42 PM
hi, if someone is still interested...
here is the cooler made from a kitchen bowl with 120mm ultra kaze cooler. 133cfm at 3000rpm. new barbell weights.
#14 eyepiecedropper
eyepiecedropper
Posted 27 November 2012 - 12:43 PM
the cooler attached only with a snug fit, holds well...
