Orion XT 6 Classic - Where to obtain Cradle?
17 replies to this topic
#1 madscientist
madscientist
Posted 20 November 2012 - 03:41 PM
Hi guys.
I just picked up this scope for $40 US at a yard sale just down the street from my house. The optical assembly is in great condition. It is even collimated. However, the cradle has suffered water damage and it really is non salvageable. I told the lady that I would only take the optical tube since the cradle really was falling apart. The scope had been kept in the garage since her son went to college earlier this fall but heavy rain had flooded the garage and severely affected the base of the scope. The tube, on the other hand, remained in excellent shape and was unaffected by the water. Do you guys know where I can purchase the cradle separately from the telescope? Thanks.
#2 Gastrol
Gastrol
  • Loc: los angeles
Posted 20 November 2012 - 03:55 PM
It will be next to impossible to find a replacement base.
I would just build a new simple base out of 3/4" plywood.
#3 madscientist
madscientist
Posted 20 November 2012 - 03:59 PM
Thanks. Any ideas on how to get started on that? I am not very handy when it comes to working with wood.
#4 GpB311
GpB311
  • Loc: Los Angeles, CA
Posted 20 November 2012 - 04:03 PM
Luckily, a dob base can be a very simple design depending on what requirements/restrictions you desire or need. Ive never made one myself, but Id start by searching the atm forum for dob base projects.
#5 frito
frito
  • Loc: Fremont, CA
Posted 20 November 2012 - 04:08 PM
you should have took the base so you could of used it as a template, would have made things simpler and you could have reused the rubber feet and maybe even the center bolt and teflon bearings off it.
building on from scratch is pretty simple. you can just build it all square to make it easier and the only curved part you would need to cut is the alt bearings where the scope sits on top of the base. check out photos of the scope on the net to give you some ideas and if you need more specific info i can take photos of parts of my XT8 base. they are the same except for the width the side panels that hold the OTA are apart distance wise is different (i had an XT6 before i got the XT8)
#6 simpleisbetter
simpleisbetter
Posted 20 November 2012 - 04:13 PM
I'd also just make my own. Pickup a sheet of good 3/4" Finish Grade Birch Ply; obtain the existing base if it's still available and simply trace out the patterns of each piece, copying both the pattern and connection points. Another option is to make your own pattern; a good place to start would be the book Build Your Own Telescope from Richard Berry. For uncommon hardware such as bearing material, checkout AstroSystems.biz, and of course ScopeStuff for the Ebony Star azimuth rings.
Those over in the ATM Forum would have lots of good tips too.
#7 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 20 November 2012 - 04:18 PM
If you are not comfortable with woodworking; there are plenty of people who are, who could cut the pieces for you for a reasonalble price. Just about any carpenter; a furniture/cabinet maker, even the average "handyman". You would be surprised at how many would take on the work....
#8 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 20 November 2012 - 04:21 PM
Just another suggestion: Contact your local Astronomy Society; I'm certain this isn't the first time they will have been asked if there is anybody around who could do the work...
#9 BDS316
BDS316
  • Loc: Sol 3
Posted 20 November 2012 - 09:13 PM
Contact Mark Wagner at Astrogoods.
http://www.astrogoods.com/index.html
On the home page is a picture of an aftermarket mount that he made for my XT8
#10 kfiscus
kfiscus
  • Loc: Albert Lea, MN, USA
Posted 20 November 2012 - 11:09 PM
I have tracings of the pieces to an XT6 stock base. I made them before shipping the original pieces to another ATMer.
You have gotten a great deal and now have a great opportunity to make this scope uniquely yours.
Look up pictures of bases I've made for different dobs. They are in my gallery here on CN. I've included one example from my Z12. Good luck!
#11 jerwin
jerwin
  • Loc: Romeoville IL
Posted 20 November 2012 - 11:14 PM
dobbstuff.com has kits for ATM.
http://www.dobstuff....lbrockerbox.htm
While the cost is probably more than you want to spend, he has some pictures of the kits they sell. Might give you some ideas how to DIY.
#12 BDS316
BDS316
  • Loc: Sol 3
Posted 21 November 2012 - 07:13 AM
Looks like you have some options whether you decide to do it yourself or have someone make it for you.
A plywood base will be stronger, lighter, and can be made water resistant by applying coats of polyeurothane. You could even make it or have it made collapsible.
One option you do not have, however, is to buy a replacement from Orion themselves, as they will not sell parts to those who are not the original owners.
Unless, of course, you can find a nearby original owner of an XT6 and have him/her order it for you. Orion ships the Dob base parts in a completely separate package from the optical tube assembly btw.
#13 madscientist
madscientist
Posted 21 November 2012 - 08:26 AM
Thanks a lot for all your suggestions. I will look at the different options and pursue the most affordable. By the way, it was a great deal. That's why I got the scope even without the base. It came with 3 eye pieces, a moon filter, a star chart, and a telrad.
#14 SteveG
SteveG
  • Loc: Seattle, WA
Posted 21 November 2012 - 01:26 PM
Place an ad over on Amart. I had an XT4.5 base that I wasn't using, and I saw an ad for someone looking for one. I shipped it off, and now he has a nice dob base and mine is mounted on an EQ mount. Or you can build one as others have suggested.
#15 kfiscus
kfiscus
Posted 21 November 2012 - 04:35 PM
Original Poster, where do you live (generally)? If you have no luck with other options, I'd cut out a baltic birch base for you and ship it to you (in CONUS) if you paid for the wood and freight. You could sand and finish it to taste... The postage would be the worst part.
#16 timfiskwa
timfiskwa
  • Loc: Richardson, TX
Posted 21 November 2012 - 08:39 PM
I built a very simple design for a base and cradle from the free San Francisco Sidewalk Astronomers website dated @2005. All you need is 3/4" 4 X 8 plywood and tools. I did my 10" on a weekend. Very strong, durable, and reliable.
#17 coopman
coopman
  • Loc: South Louisiana
Posted 22 November 2012 - 10:41 AM
Home Depot sells 2' x 4' ready-cut panels of plywood in various thicknesses between 1/2" & 3/4". I have used those to make my Dob bases in the past.
#18 madscientist
madscientist
Posted 25 November 2012 - 07:13 PM
I live in South Florida. Thanks for your offer. I have been busy with work and have not had a chance to look. I have a couple of days off next week and I will use some of that time to find a base. If I can't find anything, I will take you up on that offer. Thanks, again.
