Jupiter with the 10" Meade Starfinder - Nov 18
41 replies to this topic
#26 BKBrown
BKBrown
  • Loc: Northern Virginia, USA
Posted 24 November 2012 - 11:31 AM
Congratulations on another superb image Emil!
Clear Skies,
Brian :waytogo:
#27 Kokatha man
Kokatha man
Posted 24 November 2012 - 05:56 PM
Notice the small cyclonic dark spot division next to oval BA.
That "spot" has indeed come out wonderfully Emil with it's curvilinear outline - I don't think I've seen that in any other images so far! :waytogo:
In general though I prefer the earlier image posted, it has an aesthetic for me that is both "delicate" and detailed...but that's just an example of personal opinion - maybe influenced by the fact that I've just found out I'm diabetic and I've had to start a controlled diet just before Christmas - and "leaner" is now the order of the day for me!!! ;) :lol:
#28 MvZ
MvZ
  • Loc: The Netherlands
Posted 24 November 2012 - 06:06 PM
Perhaps the attached image is a bit more delicate then.
#29 DesertRat
DesertRat
  • Loc: Valley of the Sun
Posted 24 November 2012 - 08:13 PM
A great reprocess Emil! Yes the dark spot showed an indentation at first (I see it in my images back in September) but seems to be almost divided now. Very nice catch!
Glenn
#30 GreatGigInTheSky
GreatGigInTheSky
  • Loc: Santa Clara, California
Posted 25 November 2012 - 01:29 AM
Wonderful results here, Emil -- incredible detail. Would you mind sharing what you did to process?
#31 MvZ
MvZ
Posted 25 November 2012 - 07:48 AM
Just a little bit Jeff, but only because it took me hours of experimentation and I forgot the most of what I tried. But it briefly comes down to:
<edit: at this point I thought this was going to be just a small post... >
First figure out the best recordings in the bunch. I stacked them all in AS!2, and carefuly selected the best blue recordings that were close in time to eachother (coarse sharpening, and just a lot of close-up staring). I was left with a small list of five recordings that really stood out. For green and red I also searched for the best recordings around these best blue times. In the end I was left with two sets of RGB recordings captured within 12 minutes of eachotheer.
Processed these two sets in AS!2 but I put some more effort into getting high quality results. In the end I ended up with gradient 4 and about 30 APs placed over the planet (some more smaller ones just around the GRS over structures that stood out a bit). I used drizzle 3x basically to just enlarge the image a bit, it didn't really bring out more details (but perhaps did help just a tiny tiny tiny bit in alignment quality).
Then these stacks were brought to photoshop, and I processed them using a macro I wrote specifically for these recordings. It comes down to 1) finer smart sharpening using more accurate 2) small gaussian blur 3) coarser smart sharpening using more accurate 4) another smart sharpening stage. The result was actually still quite subtle, but most of the finer details could be more easily seen.
I resized them to 50% (so now we are working at 150% of the original size) and loaded them in winjupos to do image derotation. This took a lot of effort, it was very difficult getting the channels to line up perfectly. I ended up with a couple of images that contained the six derotated rgb stacks . These were openened in Photoshop again, were I combined them according to the specific noise levels in the two R's, G's, and B's.
Then I adjusted the color balance, but made sure there was some headroom for further sharpening (you don't want to clip the images of course). I kept this color balance proto-stack, and played around with this for a couple more hours to get to the images you just saw ;). This included some layering to get rid of some slight edge color problems, several fine sharpening steps again with smart sharpening, and finally a little bit of noise reduction.
To be honest, I don't really remember all the steps I did, I just had a lot of fun playing around and carefuly observing the effect of each step. If it didn't seem to work out, I went a few steps back and tried again with different settings. For me processing is never just a fixed routine (although certain elements are fixed). I always try to get the most out of each particular image. Especially now I imaged with a different camera with a different image scale, it was important to be flexible with processing. This was of course not the most time efficient way of processing, but in the end I did learn some new tricks.
Then there is also a matter of taste of course. Some find the images to soft or too harsh. I just try to get an image that I'm pleased with. Sometimes it is a bit more on the soft side, but now I was rather focused on trying to get that cyclonic dark spot division . This meant I pushed the image overall a little bit further than I perhaps normally would have done.
#32 GreatGigInTheSky
GreatGigInTheSky
Posted 25 November 2012 - 02:21 PM
Emil,
Thanks very much for taking the time to write all that down. This does give me some ideas to try. At some point, I'll probably go the monochrome camera route and the whole Winjupos thing, but for now, it's color data I'm working with.
Thanks again, and congratulations on the marvelous results.
#33 edsplace
edsplace
Posted 01 December 2012 - 09:25 PM
I just purchased one of these cameras, and am very excited. I also sold my DMK21. I then did some more research on the Aptina AR0130CS/MT9M034 Cmos chip and find great looking numbers, but then I read ROLLING SHUTTER! I am freaking out a bit that I sold my global shutter CCD for a rolling shutter CMOS camera. The planet moves on screen when I am using my 16" dob, even moves a lot more when I am using my CPC1100. Did you find any problems in capture or stacking with the rolling shutter?
#34 wenjha
wenjha
    Vendor
  • Loc: SuZhou China
Posted 01 December 2012 - 11:54 PM
Hi edsplace
I don't think rolling shutter cares much.
because if the planet moves very fast on screen then if must because of wind or bad seeing.it is not because of the rolling shutter itself.
#35 wenjha
wenjha
    Vendor
  • Loc: SuZhou China
Posted 01 December 2012 - 11:55 PM
Very nice final image!I would like to add it to my gallery if you don't mind Emil
#36 Kokatha man
Kokatha man
Posted 02 December 2012 - 12:49 AM
Forget the "techno-babble" about rolling shutter image-smearing as opposed to global shutter capabilities with planetary imaging Ed - someone using another cmos camera with a rolling shutter reported no issues whatsoever in their imaging.....but let me tell you brother, I'm the laziest dog-gone mount setup imager you'll come across in a month of Sundays mate!!! :shocked: - I use a Wixey to get a rough altitude, an old compass for azimuth and I'm off and running imaging.....I make corrections every second or 2 at least and the other night the wind was so bad the image made a pinbal look slow and more geriatric than me! :lol: I have never had an ounce of trouble with "smearing" and the ASI120MM!
My mantra - "good PA is for sissies!" :roflmao:
#37 edsplace
edsplace
Posted 02 December 2012 - 08:31 PM
Will I'm using dobs and alt/az mounts PA Goes back to my dark skies living..., I loved deep space imaging.
I hate to hijack this thread... but the rolling shutting is not from others taking about it. I have made two CMOS cameras with rolling shutter, one was based off a microscope camera (the same one the LPI was based off of) and the other was made from a chip/board set that FCcam produced (this was the same as the SAC4.2 and Orion's second generation planetary camera) the microscope based one didn't have much problem with the rolling shutter, it did have some crazy artifacts when you moved the planet around to much. The second one I made was horrible, if you moved much during capture the file would end up unstackable... It was very finicky. So my "What did I do! " moment Is not from people's technobabble, but my own experience. I had made a mental note to not use progressive scan sensors any longer. The images I have seen from this camera do not look like they came from a progressive scan camera, and that is why I didn't do much research beyond the companies web page before purchasing. I was surprised to see the quality of image from a CMOS and from some crazy reason thought that they had figured out a way to use this technology with soe sort of global shutter, but I thought about it more that makes no sense Deep in my heart I knew they had to have a rolling shutter. Anyway I am still excited and my camera should be here tomorrow. Glad the effects of a rolling shutter have been seen using this camera on planets.
#38 Kokatha man
Kokatha man
Posted 02 December 2012 - 09:21 PM
.....there was a bit of "tongue in cheek" about my post Ed, although I was deadly serious about the degree of movement I nearly allways have of the planet onscreen: the salient point is that if you look a Emil's image or my lastest threads you will have to agree that the camera delivers the goods!
I think you will enjoy your new camera and in my latest thread I've given a rough guide to one set of values you might like to experiment with using the ASI120MM... :)
#39 MvZ
MvZ
Posted 03 December 2012 - 07:46 AM
I did not experience any problems during two nights playing around with the camera. The first night there was quite a bit of wind, and Jupiter was bouncing up and down the screen a lot - it bounced off occasionaly - but I had no trouble stacking the final image and I did not see any artifacts.
I guess that the speed of the rolling shutter matters a lot (?). A relatively slow rolling shutter should introduce weird artifacts, but if it is fast enough (like it seems to be with this particular camera), it doesn't really matter.
I think you will be pleased with the camera and find that there is no problem with the rolling shutter.
Sure Sam, you can use it as long as you add my name.
#40 Kokatha man
Kokatha man
Posted 03 December 2012 - 09:41 AM
.....just a plug for AS!2 here Emil along the same lines as you've stated above - a few times I've stacked images where the planet has quite regularly gone awol on the screen during capture due to winds - and AS!2 just seems to laugh it off..! :waytogo: :waytogo:
#41 lcd1080
lcd1080
  • Loc: Maryland, USA
Posted 03 December 2012 - 07:50 PM
Oh my gosh Emil after seeing the high quality of your images it's time to start thinking about a CMOS camera, maybe in time for the coming Saturn season!
Pete
#42 wenjha
wenjha
    Vendor
  • Loc: SuZhou China
Posted 04 December 2012 - 02:15 AM
Thanks Emil
of course I will add your name
