Coulter Optical Questions
12 replies to this topic
#1 fishook
fishook
Posted 21 November 2012 - 03:59 PM
Hi All,
Does anyone know (have any pics) what variety of sizes Coulter Optical offered for Ortho's?
Dan
#2 ji4m
ji4m
Posted 21 November 2012 - 06:18 PM
I can only speak for the two I bought - 12.5mm and 25mm. They are volcano top, and do not say Coulter on them. They came in a light gray box with white bottom. I still have them, so I can offer up a photo later if no one else comes forward. They have the ubiquitous ortho appearance, so no surprises in these I own.
#3 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 21 November 2012 - 07:50 PM
I had a Coulter ortho 6mm which I recently sold. Here are some pics:
#4 Sarkikos
Sarkikos
Posted 21 November 2012 - 07:51 PM
#5 Mariner@sg
Mariner@sg
  • Loc: Little Red Dot
Posted 21 November 2012 - 08:42 PM
I think they're in the same range available as Circle T orthos since it's from the same manufacturer.
#6 mgwhittle
mgwhittle
  • Loc: Chattanooga, TN
Posted 22 November 2012 - 01:50 AM
I am pretty sure the one being shown is not a circle T. I say this based on the construction of the eye lens opening, the type of letters stamped Japan and the finish. I believe it's missing a sticker that would have been applied to the side of the upper barrel that had the makers mark symbol of a what I can only describe as an 8 with two lines going through it.
On the other hand, I could be wrong.......
#7 catboat
catboat
  • Loc: Maine
Posted 22 November 2012 - 02:30 AM
Here's a link to a CN classified that shows the sticker Mark mentioned. If you "supersize" the linked photo on the left and then magnify, you can see the sticker fairly well on the Kellner: a crosshair+ superimposed on an 8.
link to Coulter sticker
#8 mgwhittle
mgwhittle
Posted 22 November 2012 - 02:34 AM
Yep Edward, you are right, it's not one of those weird figure 8 orthos. But I am still suspect that the pictured one is not a circle T. But like I said I could be wrong.... :confused:
#9 catboat
catboat
  • Loc: Maine
Posted 22 November 2012 - 02:54 AM
Mark, I think the one shown in this thread by Sarkikos is the same as you mention -- just missing the sticker with the "8" mark.
But the overall build resembles Circle-T products. In the CN link I posted above, the Coulter kellner (not the ortho, my mistake) has the incised line around the lens housing, which, I think, is also typical of UO Circle-T kellners -- altho I don't have an example on hand. So I'm on the fence about whether or not these are Circle-Ts.
Any comments on how the Coulters perform vs. other Japanese volcano tops?
#10 Mariner@sg
Mariner@sg
Posted 22 November 2012 - 09:36 AM
My take is the make of the EP and the engraving is the same as the Circle-T orthos. The stickers may be missing for these early production pieces, which are usually stamped with JAPAN and a small circle-t insignia (Stamping is not perfect, some portions end up so shallow you can hardly see them).
#11 Sarkikos
Sarkikos
Posted 22 November 2012 - 05:57 PM
As a matter of course, I take all stickers off of my eyepieces. I don't want any chance of one coming loose and gumming up the optics. It's very dewy where I observe, so that could happen. I actually look through my eyepieces, not just look at'em.
What were those manufacturers thinking? Never put stickers on optics! :4
:grin:
#12 moynihan
moynihan
  • Loc: Lake Michigan Watershed
Posted 23 November 2012 - 01:50 PM
I just went and grabbed my 12.5mm Coulter Ortho i bought long ago, (when i bought my original design Coulter Odyssey 10.1 f/4.5, new...)
On the silver metallic barrel, it clearly says JAPAN then a circle with a T in it. I would not be surprised if they had different makers through the year.
BTW: A good standard ortho, same view as my U.O. volcano top 12.5mm.
#13 Mike Lynch
Mike Lynch
Posted 25 November 2012 - 10:39 AM
Regarding that 6mm Coulter ortho mentioned above, I was the buyer of the one sold by Sarkikos, and I was out for a short time last night with my 127mm f/5.5 homemade refractor looking at Jupiter through it. Clearly (pun there), this was the best of all the eyepieces I tried on Jupiter.
The scope is fast, and I use it typically for deep-sky viewing. So I had a fringe-killer filter, a Baader Moon and Skyglow filter and a stop-down mask to get my best views. Had to let the scope cool down for a while, too. The major belts showed some detail and the Great Tan Spot was easily visible at 116x.
A more 'planetary' scope I'm sure would have done even better.
Mike Lynch
Frankfort KY USA
