Strange problem with electronics
4 replies to this topic
#1 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 22 November 2012 - 07:59 AM
This has happened a few times. My scope gets it power from a 13.8 regulated power supply. A few times, when I turn on the scope, the power light comes on but the handset does not. Then I will turn off the power and replug the handset and everything works fine. Any ideas what would cause this? Thanks. I do not believe its the handset because when it is like this, I can't connect to Nexremote either.
#2 rmollise
Posted 22 November 2012 - 04:40 PM
Which scope? Which firmware build for the HC?
#3 Footbag
Footbag
  • Loc: Scranton, PA
Posted 23 November 2012 - 11:30 AM
Could one of the pins in the handset not be seating correctly?
#4 rmollise
Posted 23 November 2012 - 02:53 PM
Some revs of the firmware have this very problem. If your HC has an older version, update it.
#5 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 24 November 2012 - 09:01 AM
Its a Celestron 11 inch SCT. The HC firmware is 4.21.
