Alternative to Firecapture software for a DMK 21 ?
3 replies to this topic
#1 Michael Morris
Michael Morris
    Member
  • Loc: Worcestershire, UK
Posted 22 November 2012 - 03:28 PM
At the moment I'm using the manufacturer-supplied software for image capture with my Imaging Source DMK 21 618 camera - IC Capture. It gives me great frame rates and is pretty reliable and easy to use. However, ideally I would like something that will do image capture and ASCOM control focus and run an ASCOM filter wheel.
FireCapture software should do all of these, but I've had nothing but problems with it because it never seems to be able to run at anyhthng like the high frame rates I can get when running IC Capture.
http://firecapture.wonderplanets.de/
Does anyone know of any other software that will do image capture with a DMK 21 618 camera and ASCOM control focus and run an ASCOM filter wheel?
#2 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 22 November 2012 - 03:32 PM
Hi Michael,
Not sure what your setup is doing differently, but I can get 60fps full-frame from my DMK21AU618 using FireCapture on an aging, single-processor WinXP PC. And this is also using FireCapture's autoguiding to keep Jupiter centered in the FOV.
Grant
#3 Michael Morris
Michael Morris
    Member
Posted 22 November 2012 - 03:37 PM
Hi Grant
I can't work out what I'm doing wrong either, that's why I starting to see if there are alternatives.
#4 PiotrM
PiotrM
  • Loc: Poland
Posted 22 November 2012 - 05:14 PM
IC Capture AS has different write performance than FireCapture for some reason... and there isn't rather any alternatives for that.
