Surveyor Tripod Question
8 replies to this topic
#1 BobH
BobH
  • Loc: Right Coast
Posted 29 November 2012 - 10:54 AM
Does anyone have any suggestions on how to install a post on the flat top of a surveyor's tripod so that the azimuth adjusting screws of a GEM mount can be used in polar aligning? :question:
Bob
#2 *skyguy*
*skyguy*
  • Loc: Western New York
Posted 29 November 2012 - 11:56 AM
I've replaced a number of "shaky" telescope tripods with surveyor tripods. I use simple blocks of wood to make the adapter plates. It should be relativity easy to make a pillar out of wood.
#3 StarStuff1
StarStuff1
  • Loc: South of the Mason-Dixon Line
Posted 29 November 2012 - 12:11 PM
This is an easy fix. Simply drill a hole in the top plate and put a hex head bolt in. Align the flats of the bolt head to the az adjusting screws. You may have to place a few flat washers under the bolt head to have the proper alignment.
#4 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 29 November 2012 - 10:47 PM
If you want it to look "professional", you can buy a stainless steel threaded stud from McMaster-Carr:
http://www.mcmaster....ed-rods/=kds4wr
But StarSuff's idea will work just as well.
-Dan
#5 Goodchild
Goodchild
Posted 30 November 2012 - 07:43 AM
Where should this hole be drilled? I've heard in line with one of the tripod legs. True? And how far from the outside edge of the tripod top plate?
#6 Midnight Dan
Midnight Dan
Posted 30 November 2012 - 10:43 AM
Yes, in line with one of the tripod legs.
How far back from the edge? As far as it needs to be for your mount. There is no "standard" distance for all mounts.
-Dan
#7 Goodchild
Goodchild
Posted 30 November 2012 - 07:56 PM
Thanks, Dan!
#8 hottr6
hottr6
  • Loc: 7,257', Magdalena Mtns, NM
Posted 01 December 2012 - 11:07 AM
You could always buy a CG5 adapter plate from Universal Astronomics, that adapts a CG5 to the top plate of a surveyors tripod. The post for the az-adjustment is built-in and works well.
#9 Goodchild
Goodchild
Posted 01 December 2012 - 01:11 PM
Shane, what keeps it from rotating on the top plate?
