Jupiter 11-29-12 More Good Seeing
21 replies to this topic
#1 Hillbrad
Hillbrad
  • Loc: Nashville, Tennessee
Posted 01 December 2012 - 12:53 AM
I was lucky enough to get another good night with the GRS in view. The seeing wasn't quite as nice as it was last week but it was still great. I still delt with dew inside the ota again...but this time I just heated most of it off with the dryer before I started, and then waited about 15 minutes for the corrector to cool back down. There was a little bit of jet stream that caused some hi res. shaking from time to time but there was still plenty of detail in every channel.
This composite was taken with the C14 and flea3 at 7:28UT on 11-29-12. Thanks for looking!
#2 Hillbrad
Hillbrad
Posted 01 December 2012 - 12:54 AM
And here is a closeup of Io compared to the NASA JPL simulation on the left. This is a blend of green and red light.
#3 rik ter horst
rik ter horst
  • Loc: Zuidwolde, the Netherlands
Posted 01 December 2012 - 02:21 AM
Excellent shot again Brad! Processing is awesome!
Rik
#4 Foehammer
Foehammer
  • Loc: Cyprus
Posted 01 December 2012 - 02:28 AM
Astonishing shot! Something to look up to!
#5 Kokatha man
Kokatha man
Posted 01 December 2012 - 03:58 AM
Lovely Brad!!!
#6 Freddy WILLEMS
Freddy WILLEMS
  • Loc: Hawaii, Honolulu
Posted 01 December 2012 - 05:20 AM
Excllnt !!! :band:
#7 Rankinstudio
Rankinstudio
  • Loc: Southern UT
Posted 01 December 2012 - 09:27 AM
Awesome shot.
#8 astrovienna
astrovienna
  • Loc: The NoVa White Zone
Posted 01 December 2012 - 10:34 AM
Another beautiful shot, Brad. How do you get so much detail on the moons? Mine still look pretty much just like diffraction patterns, even in excellent seeing and with lots of frames. While there's a little detail around the limbs, the center always tends to be nothing but a big dark dot.
Kevin
#9 bunyon
bunyon
  • Loc: Winston-Salem, NC
Posted 01 December 2012 - 12:20 PM
Another outstanding set!
#10 BKBrown
BKBrown
  • Loc: Northern Virginia, USA
Posted 01 December 2012 - 12:37 PM
That's another stunning beauty Brad! :applause: You are having quite the run lately, care to share some of your seeing :grin:
Clear Skies,
Brian :waytogo:
#11 Baron
Baron
  • Loc: Rome, Italy
Posted 01 December 2012 - 01:28 PM
Very good!
#12 DesertRat
DesertRat
  • Loc: Valley of the Sun
Posted 01 December 2012 - 04:29 PM
Another fine image Brad! Wishing you all the best and more seeing like that!
Glenn
#13 lcd1080
lcd1080
  • Loc: Maryland, USA
Posted 01 December 2012 - 04:36 PM
The complexity of the GRS wake is well accounted for in your image Brad; and what convincing surface detail on Io! It's very close to the JPL simulation.
Pete
#14 Erik Bakker
Erik Bakker
  • Loc: Netherlands, Europe
Posted 01 December 2012 - 05:32 PM
Brad,
What can I say? Absolutely stunning image of Jupiter :bow:
#15 Daniel Chang
Daniel Chang
  • Loc: Hong Kong
Posted 01 December 2012 - 05:52 PM
Excellent shot !
#16 Az Frank
Az Frank
  • Loc: Tucson Arizona
Posted 01 December 2012 - 07:40 PM
Another Wow factor Brad! One beautiful image!
#17 Hillbrad
Hillbrad
Posted 08 December 2012 - 01:49 AM
Thanks for all the comments guys! Work has been really busy but I finally got around to processing one more from this batch. This one was taken at 5:54UT before the GRS had rotated into view. I think the seeing was about the same. Hope that jet-stream will get out soon while Jupiter is still big!
#18 Hillbrad
Hillbrad
Posted 08 December 2012 - 01:54 AM
Kevin: For the moons I have been experimenting with the processing recently. I've found that using a very small amount of frames and then not sharpening too much as been the best result. For this one of Io and my recent Ganymede, I used only 250 frames out of 12,000 per color. Then I drizzled 1.5x in AS2! and used a little bit of wavelets in Registax. No deconv. at all was used. Hope that helps!
#19 sfugardi
sfugardi
  • Loc: CT
Posted 08 December 2012 - 09:47 AM
Brad, absolutely stunning images! Detail and color are processed perfectly. What f-ratio/focal length are you using? Also, what is the gain setting on the B channel? Lately I have been pushing higher going from f25 to f27 but getting noiser images having to increase the gain up to achieve 65% brightness and it seems to be in the wrong direction. I am thinking of going lower next time. From the super image quality it looks like you have the optimal setup. Thanks in advance for the advice and for posting these beauties. These should go straight to S&T!
Steve
#20 edsplace
edsplace
Posted 08 December 2012 - 11:02 AM
Fantastic image!
#21 Kokatha man
Kokatha man
Posted 08 December 2012 - 11:05 AM
Brad, I reckon that last image must be close to your personal best yet, despite the absence of Jove's most photogenic feature, the GRS.....high praise considering your lofty achievements this year and last....! :applause: :applause: :applause:
#22 Hillbrad
Hillbrad
Posted 08 December 2012 - 12:09 PM
Thanks guys. Not sure if this is my best or not Darryl, but I'm glad it turned out well! It is hard sometimes to be subjective of the image quality when it's the "boring side" :)
Steve: I shot these around F29. From your latest images it looks like you are really finding the sweet spot with your scope and cam. I usually keep the gain in the 2700's in firecapture for all three channels. Sometimes I'll even push blue up to 3000 if the transparency is poor. Here is the firecapture data file for the Blue channel in the above image:
Filename=B_055615.avi
Date=29.11.2012
Start=05:56:15
Duration=69s
Frames captured=3523
Camera=Flea3 FL3-FW-03S1M
ROI=560x480
Profile=Jupiter
Diameter=48.38"
Magnitude=-2.83
CMI=108.9° CMII=104.1° CMIII=162.7°
FocalLength=10200mm
Resolution=0.11"
Filter=B
FPS=55
Shutter=19.26ms
Gamma=578 (off)
Brightness=0
Exposure=1
Gain=2741
Sharpness=512 (off)
Histogramm(min)=0
Histogramm(max)=198
Histogramm=77%
Noise=23.408678
AutoAlign=false
PreFilter=none
Limit=69 Seconds
