Direct computer control of scope ?
8 replies to this topic
#1 BigC
BigC
  • Loc: SE Indiana
Posted 01 December 2012 - 09:26 AM
Search didn't find me anything so here is the question:
Are there any computer programs and interfaces(if needed) that would directly control the motors of various goto scopes and that do not need a working han controller ?
I know hand controllers can fail and that in the case of donated and estate sales the controllers are sometimes seperated or lost.Usually the price of a repacement controller from the original company costs more than I want to spend.
#2 Bill-in-BC
Bill-in-BC
  • Loc: British Columbia
Posted 01 December 2012 - 11:14 AM
MaxIm DL allows telescope control from the keyboard, but you need to do your initial alignment using a hand controller. After perfoming a sync on a couple of stars using the hand controller, you can then use MaxIm DL for all your GOTO. (I'm using an LX200 Meade.)
#3 groz
groz
  • Loc: Campbell River, BC
Posted 01 December 2012 - 04:28 PM
Cant say about the others, but, the EQ6 / HEQ5 / EQ3 series, based on the synscan controller, can all be operated directly from a pc, without the hand controller, buy simply purchasing a serial converter for them, commonly called the 'eqmod' type stuff. It's just an rs-232 -> 3Vttl converter. Shoestring astronomy sells the inexpensive eqdir module that does the trick, there are other variants out there.
#4 A. Viegas
A. Viegas
  • Loc: New York City/ CT
Posted 01 December 2012 - 06:23 PM
Celestron has software called nexRemote, this usually comes with a new telescope or mount. The new CPC line of telescopes have a "pc" port that you connect to a standard rs232 type cable and in turn, using the nexRemote software you can control the telescope without a hand control.
However, used hand controls can be bought on EBay for $50 so that is usually a better option...
Al
#5 JAT Observatory
JAT Observatory
    NOT a Wimp
  • Loc: In the Primordial Soup
Posted 02 December 2012 - 06:55 AM
It is more a function of the scope not the software. If the brains are in the scope most scopes will allow total control from a computer without need for the controller. If however the brains are in the controller, you'll need the controller.
#6 rmollise
Posted 02 December 2012 - 09:23 AM
Two thus far:
NexRemote (Celestron scopes).
EQMOD (SynScan scopes--Orion, SkyWatcher, etc.)...
#7 *skyguy*
*skyguy*
  • Loc: Western New York
Posted 02 December 2012 - 10:47 AM
Two thus far:
If you have a Meade LX200 "Classic" scope without the handcontroller ... you can purchase the $30 "LX200 Keypad Simulator" dongle to initialize the scope and then use any planetarium program that has the LX200 drive protocol to control the scope:
http://www.dv-fansle..._keypad_sim.htm
#8 Charlie B
Charlie B
  • Loc: Sterling, Virginia
Posted 02 December 2012 - 11:25 AM
Two thus far:
There is also Gemini for the Losmandy G8, G11 and Titan, HGM 200 and MI250. It also will support other "custom" mounts, but I don't know much about that feature.
Charlie B
#9 BigC
BigC
  • Loc: SE Indiana
Posted 02 December 2012 - 02:07 PM
Al
OK,I am seeing that used hand controller may be the better and simpler solution.
