iOptron SmartEQ Pro Mount w/ Which Scope...
9 replies to this topic
#1 RefracNick
RefracNick
  • Loc: Port Crane, NY USA
Posted 03 December 2012 - 06:16 AM
After considerable research, I have arrived at the conclusion that the following package will fit my needs best:
- An iOptron SmartEQ Pro mount (payload capacity of 11 lbs.)
- One of the following three small refractors:
1) William Optics ZenithStar 71 ED, f/5.9, 6 lbs.
2) Astro-Tech AT72ED, f/6, 5 lbs.
3) Stellarvue SV 70ED, f/6, 4.75 lbs.
Package will be used for casual observing, and wide-field AP with a Canon DSLR. Any opinions on which scope of the three would perform best? Any advice is appreciated!
#2 Cyclop_si
Cyclop_si
  • Loc: Slovenia
Posted 03 December 2012 - 06:58 AM
No. 2) for me, please. :)
#3 Brian Gibson
Brian Gibson
  • Loc: Oakville, Ontario
Posted 03 December 2012 - 09:56 AM
I can't really comment on the choice of scope but the SmartEQ does handle my TV-85 which weighs closer to 10 lbs but I had to use a 4 lb counterweight because the standard 2 lb counterweight will only balance an 8 lb payload.
Brian
#4 ghataa
ghataa
  • Loc: Central, NJ
Posted 03 December 2012 - 03:12 PM
Brian,
Did you do AP with it?
George
#5 Brian Gibson
Brian Gibson
Posted 03 December 2012 - 05:37 PM
I haven't done AP using the TV85 George but I have mounted my Olympus OM-D and 150mm f/2 (EFL 300mm) which produced the image below of Orion's sword and M42. I was able to take 60 second unguided shots with this setup and stack in Nebulosity. I simply did a polar alignment using the optional polar scope reticle and then turned on the drive! I have a 70mm Pronto and 0.8 reducer/flattener that I plan to try for AP on this mount.
Brian
#6 Astronewb
Astronewb
  • Loc: Connecticut
Posted 05 December 2012 - 09:29 AM
Brian,
George
George, here's a test image taken off a SmartEQ Pro,
Test Shot of IC1396 w/60mm Borg by Astronewb2011, on Flickr
Used a 60ED Borg with a .7 reducer, 60 and 120 second exposures under a bright moon with a Nikon D5100. Guided with a 50mm/SSAG. Hope the info helps.
Paul
#7 Ed Whitney
Ed Whitney
  • Loc: Palm Coast, Florida
Posted 05 December 2012 - 03:20 PM
The AT72ED is a "honey" of a small scope. The back is rotatable so should work fine for AP too.
And, Welcome to Cloudy Night's Forums!
#8 ghataa
ghataa
  • Loc: Central, NJ
Posted 05 December 2012 - 04:55 PM
Brian and Paul,
Looks really encouraging! I have asked my wife to put the Pro on the Christmas list along with the SV70.
Best,
George
#9 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 26 January 2013 - 12:52 AM
George,
Did you end up getting it? Paul, I was thinking about an iEQ Pro as a portable mount for traveling... Can you estimate the total weight you're putting on it with your rig? Great picture!
Chris
#10 ghataa
ghataa
  • Loc: Central, NJ
Posted 26 January 2013 - 08:02 AM
Hi Chris,
I did get it. But I need to spend more time with it as my gotos were way off. I did slap just a DSLR on it and at 85 mm easily got 4 min subs with good tracking. I need to get this sorted out befor trying autoguiding.
Best,
George
