SBIG ST-2000XM and changed e-/ADU
3 replies to this topic
#1 makintosz
makintosz
Posted 04 December 2012 - 04:26 AM
Hello,
Recently I bought from someone an SBIG ST-2000XM Camera.
I did few tests and I found that Standard Deviation in bias frames i about 2,5x higher than my ST-2000XCM (now sold).
It was weird since both cams have same chip KAF 2020 etc.. so I searched further.
What I finally found is that e-/ADU is changed from oryginal 0.6 value to 0.26.
What can I do to switch it back to oryginal ? I dont want to return it to the guy I bought it since everything else is working fine.
I tried to contact SBIG about it to no avail so far...
I searched whole internet and didnt found any solution.
Dear Forum Members, Can You help me ?
Thanks in advance!
Michal
#2 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 04 December 2012 - 06:14 AM
Wrong forum. Try emailing SBIG again, they're definitely the best source for this type of information.
#3 ccs_hello
ccs_hello
Posted 04 December 2012 - 08:37 AM
Michal,
Definitely wrong subforum. You can also try CCD subforum.
For others:
a useful info to compare astroimager with others...
(Many high-end) astro-imagers tend to be designed/optimized with a factory preset gain (ISO / gain / e-/ADU), post the actual sensor output stage. Many models are factory fixed at a preset value (though still modifiable) not easily modified through menu setting by the end-user. The value chosen tends to be optimized toward the best possible S/N for the optimal image quality, not the highest possible gain (some loosely call it sensitivity.)
Clear Skies!
ccs_hello
#4 makintosz
makintosz
Posted 04 December 2012 - 09:50 AM
Thanks, I will post it in the CCD forum. I tought that CCD forum is more for imaging and procesing in itself.
