Baader VariLock T2 Extension Tube 29-46mm
8 replies to this topic
#1 svthomas
svthomas
  • Loc: Billings/Bozeman, MT. USA
Posted 05 December 2012 - 03:25 PM
I just purchased a used QHY8 camera, and I am now shopping for spacers to get the proper distance between the Field Flattener (AT2FF) and the sensor. I came across the following product, and am curious if anyone has any experience or thoughts on it. Would this be rigid enough? The reason I ask is that this would actually be convenient when switching between a reducer/flattener to a standard flattener when changing scopes, as the corrective products I will be using require different spacing.
Link to said product:
http://www.optcorp.c...w=VariLock&st=2
Thanks in advance for your help.
-SV
#2 tecmage
tecmage
  • Loc: Glenview, IL
Posted 05 December 2012 - 06:33 PM
#3 wolfman_4_ever
wolfman_4_ever
  • Loc: El Segundo, Ca, So. Cal
Posted 05 December 2012 - 08:18 PM
Works Great!
#4 psandelle
psandelle
  • Loc: Los Angeles
Posted 05 December 2012 - 08:23 PM
I second the "works great" notion. The guys from Boren-Simon (the PowerNewt guys) were the ones who first suggested it to me, so if they were good with it, I figured I'd be good with it. Easy, straightforward, no flex. I have the shorter one as well, for when I use a filter tray.
Paul
#5 WadeH237
WadeH237
  • Loc: Snohomish, WA
Posted 05 December 2012 - 11:03 PM
I have an AT6RC with *lots* of imaging equipment on it. I have one of these extensions between my rotator and ST10/CFW8. My Optec focuser has only 0.6" of travel, so the spacing needed to be precise. Instead of having a custom spacer machined, I got the VariLock.
The VariLock works beautifully. I have the sensor on my ST10 right in the middle of that short range.
#6 wolfman_4_ever
wolfman_4_ever
Posted 05 December 2012 - 11:25 PM
Pretty much anything from Baader "Works Great"!
#7 Mike Wiles
Mike Wiles
  • Loc: Goodyear, AZ
Posted 05 December 2012 - 11:46 PM
I used one to get the spacing correct between a QHY8PRO camera and a Hotech field flattener...essentially the exact same thing you're asking. It was a perfect solution. You should order one. You'll be happy.
#8 svthomas
svthomas
Posted 06 December 2012 - 02:10 AM
Fantastic, thanks for the help everyone--always nice to see such positive feedback. I will get one of these ordered tomorrow and check it off of my list. :jump:
-SV
#9 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 06 December 2012 - 06:13 AM
I just bought one these too :). Like everyone said, anything from Baader works just great so I took a plunge. Good review on Agena as well.
