7 hours of Jupiter rotation - 11/17 & 11/19
2 replies to this topic
#1 zAmbonii
zAmbonii
  • Loc: Ypsilanti, MI
Posted 08 December 2012 - 03:12 PM
I never finished up processing of images that I had taken on Nov 17th. I'll just refer you to images posted during capture. I went and took the images from the 17th and 19th and created a couple of animations. The first animation is just from images taken on the 17th. The second is a combined animation from the 17th and 19th, just to see how much of a full rotation I ended up with. Turned out to be about 7 hours worth.
Click on the image or link to view the animations.
Jupiter 11/17/12 by zAmb0ni, on Flickr
7 hours of Jupiter 11/17, 11/19/12 by zAmb0ni, on Flickr
#2 edsplace
edsplace
Posted 08 December 2012 - 09:29 PM
That is excellent! How did you keep the color, brightness, contract so perfect for all the images?
#3 zAmbonii
zAmbonii
Posted 08 December 2012 - 09:53 PM
The camera white balance settings are usually the same between one session to another. During capture, I try to keep the histogram at the same levels throughout the captures, and I can do that on the fly in between captures with wcctrl. I usually have to turn down the gain slightly as Jupiter rises.
That is one way to keep things even between captures. When stacking, I have the "Normalize Stack" setting checked and use a value of 85%. I think that helps some also.
Finally when I bring all of the frames into photoshop, I do an autocolor run on all of the frames (I have a vb script that does all the dirty work) that gets the color straightened out. That usually evens most of the frames out pretty good, but if there is a period of bad seeing, they tend to be brighter than the others. If that happens, I manually do a difference between one frame and another and do a manual level/curves adjustment to get them to the same brightness.
If I really knew programming, I might be able to come up with an automated way of getting things absolutely perfect. But I think that is beyond the scope of photoshop and maybe something that could work in matlab or something similar.
