DIY Bahtinov Focusing Masks with lasers.
4 replies to this topic
#1 James_826
James_826
  • Loc: Mounds, Ok
Posted 12 December 2012 - 11:33 AM
Yesterday I had some fun at my local Fablab making my own Bahtinov Focusing Masks with a laser cutter. I made one for each of my scopes. I used this website to make the basic models, http://astrojargon.n...Generator.aspx. I then imported the files into Inkskape to add the labels and corner, http://inkscape.org/. Then I was able to cut them out at FabLab in Tulsa, http://www.fablabtulsa.com/. I still need to add rubber stoppers to their backs so they can hang on the scopes and I also need to polyurethane them so the last a little longer. The were made from a sheet of 1/8 tempered hardboard.
The laser cutter doing its job:
This is the machine doing the cutting:
One done, the other is cutting:
The final product completed and back home.
I can upload the pdf or svg files if anyone likes, but you really should use the website above to custom make your own so the specs are correct.
#2 Mary B
Mary B
  • Loc: Minnesota
Posted 12 December 2012 - 07:16 PM
You can increase the number of lines on a mask for full coverage in the online program. It is down in the bottom half.
#3 James_826
James_826
  • Loc: Mounds, Ok
Posted 12 December 2012 - 09:28 PM
I did not catch that, thank you.
#4 rogercelliott
rogercelliott
  • Loc: Redding, CA
Posted 13 December 2012 - 12:34 PM
How much did you pay for this service?
Cheers
Roger
#5 Mary B
Mary B
  • Loc: Minnesota
Posted 13 December 2012 - 08:36 PM
I use black opaque acrylic sheet, no painting needed. Only downfall is they are fragile and will shatter if dropped.
