Orions Sword in 3nm NII
8 replies to this topic
#1 Bert
Bert
  • Loc: Australia
Posted 13 December 2012 - 07:57 PM
Managed to get 10x16 minutes in 3nm NII of M42 and made a mosaic with the earlier Horse head data. There is a mismatch at the overlap but it gives an idea of what is possible.
Large image 5MB FoV 6.0 X 3.4 degrees.
http://d1355990.i49....Orsword_NII.jpg
I am finding that gradients are still a problem even with 3nm filters.
Bert
Astrograph is an Officina Stellare RH200 which has a focal length of 600mm and is F3, yes F3! Clear aperture is 200mm.
FLI Atlas Focuser.
FLI ten position filter wheel CFW-3-10 with 50mm square filters.
Astrodon E series LRGB and HA, NII, SII and OIII 3nm NB filters. Also a continuum filter 5nm.
Camera is a FLI PL16803 which has a sensor size 36.8 X 36.8 mm.
The FoV of this system is 3.5 X 3.5 degrees.
Mount is a Software Bisque PMX.
#2 SL63 AMG
SL63 AMG
  • Loc: Williamson, Arizona
Posted 13 December 2012 - 08:03 PM
That's amazing!
#3 Kildar13x
Kildar13x
  • Loc: Maine
Posted 13 December 2012 - 08:12 PM
:waytogo:
#4 broca
broca
  • Loc: Ocala, FL
Posted 13 December 2012 - 08:40 PM
Amazing amount of dust you were able to capture and process out. Well done!
#5 psandelle
psandelle
  • Loc: Los Angeles
Posted 13 December 2012 - 09:03 PM
WHOA!!!!
Nice pic!
Paul
#6 rigel123
rigel123
  • Loc: SW Ohio
Posted 13 December 2012 - 09:47 PM
That is simply unreal!! Amazing!
#7 David Pavlich
David Pavlich
    Transmographied
  • Loc: Mandeville, LA USA
Posted 13 December 2012 - 10:18 PM
That's a terrific image! :bow:
David
#8 freestar8n
freestar8n
Posted 14 December 2012 - 08:30 AM
Hi-
That's a nice image and it has potential, but I would be concerned that the mismatch is related to using 3nm at f/3 with wide field. Trying to separate Ha from Nii is fundamentally difficult with fast optics, and due to the large and variable angles through the filter, I would expect a variation in the ratio of Ha/Nii across the image. In a single image this wouldn't show much, even though it is present - but in a montage, any difference in this ratio would produce a mismatch.
I can't say for sure that is what is happening here, but some amount of variable mixing is inevitable across the image at fast f/ratio. I don't think there is a way to fully isolate Ha from Nii with fast optics - you either have to go wider band and combine them, or slower f/ratio to keep them separate.
This effect also may be related to your issue with gradients.
Frank
#9 Konihlav
Konihlav
Posted 14 December 2012 - 10:38 AM
Bert - what a nice contrast :-) great!
Frank - I would not be afraid of F/3 and 3nm NII as the Astrodon filter is really ubercool (simply great!), but you are right that even that the Astrodon filters have very high transmittance and steep/narrow bandwith there probabably is some small % of Ha emission included in the image as the 658nm of NII in 3nm allows to pass light in between 656.5nm to 659.5nm in ideal case... and Ha is 656.3 if I am right... so the small % may be eventually 50% ;D who knows ;)
so good point! with slower scope it would be much better separated, but who cares in ORION ;D
