Lost RA Drive on my CGEM 800
3 replies to this topic
#1 Zebenelgenubi
Zebenelgenubi
  • Loc: Texas, USA
Posted 13 December 2012 - 09:42 PM
I set up my C9.25 this evening only to find the RA drive motor isn't working. No slew,no whiring. The declination drive is fine. I rebalanced the setup and adjusted the clutch without effect. How does one trouble shoot this situation? The mount is only about one year old.
#2 RTLR 12
RTLR 12
  • Loc: The Great Pacific NorthWest
Posted 13 December 2012 - 10:58 PM
Remove the control panel and swap the connectors on the motors and see if the RA works.
Stan
#3 Zebenelgenubi
Zebenelgenubi
  • Loc: Texas, USA
Posted 14 December 2012 - 08:45 AM
Stan,
Good idea. I had a chance to look at the symptoms since my initial post. I found that the RA will slew counterclockwise (from Polaris point of view) while straining but will not go clockwise independent of how I balance the mount.
#4 RTLR 12
RTLR 12
Posted 14 December 2012 - 09:28 AM
Now that sounds mechanical in nature, rather than electronic. You can try backing off the worm gear adjustment on the RA axis to see if it's a binding problem of the worm gear/ring gear.
Stan
