GM8 RA clearance issues with Gemini2!!! Hello!
8 replies to this topic
#1 old_frankland
old_frankland
  • Loc: San Francisco Bay Area
Posted 23 December 2012 - 01:51 PM
I'm just now installing the Gemini 2 on my long suffering GM8 mount and was more than alarmed with the clearance issue between the dove tail and RA motor when the scope is aimed at the zenith. I guess I should have anticipated this issue seeing how the drive motors hang out roughly twice the distance from the mount than the older stepping motors.
Not having access to the zenith and a good part of the meridian from the east side of the mount is a major problem if you are doing tempral timelapse videos of the sun or planets. Just as important is the potential of destroying the drive motor while manually moving the scope.
http://www.lafterhal...erreira_001.jpg
This is most disappointing and I will likely be returning the Gemini 2 and go back to my stepping motors. No other mount in the same class has this issue. Losmandy what were you thinking?
Thanks for any input.
#2 Ranger Tim
Ranger Tim
  • Loc: SE Idaho, USA
Posted 23 December 2012 - 05:06 PM
We need one of those extra spacers like I've seen for the G11. Same issue here with mine except there are regular motors on mine, not Maxxons.
#3 JoseBorrero
JoseBorrero
  • Loc: Puerto Rico Island
Posted 23 December 2012 - 05:40 PM
you will need a shorter dovetail
#4 old_frankland
old_frankland
Posted 23 December 2012 - 07:46 PM
I can move the tube rings down the dovetail for a bit more clearance, but that doesn't help with my solar refractor or C9.
#5 JoseBorrero
JoseBorrero
Posted 23 December 2012 - 09:14 PM
or made a double dovetail with the lower one shorter.
#6 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 24 December 2012 - 07:17 PM
The MI250 has a similar problem. One fix was the addition of a declination spacer that allows you to adjust for the RA motor...
Maybe you could find a machinist in your area to produce something similar?
www.mi250.com
#7 old_frankland
old_frankland
Posted 28 December 2012 - 11:05 PM
www.mi250.com
Yeah, after looking at the mount, turning a short extension is pretty straight forward and should get me access to the meridian from the east side of the mount. Good call.
#8 Raginar
Raginar
Posted 29 December 2012 - 07:51 AM
Glad I could help :D Just make sure you follow his instructions, apparently you need to re-adjust your worm gear tension to prevent damage.
Good luck! And post pictures for everyone when you're done :)
#9 RAKing
RAKing
  • Loc: West of the D.C. Nebula
Posted 29 December 2012 - 12:26 PM
Yes, it's tight in there and that is why the GM-8 comes with that tiny dovetail saddle.
A 1/2 inch spacer would be a great idea and I wish I had access to a lathe. :)
Ron
