Android App and Tablet sky safari and skyeye
7 replies to this topic
#1 Gregk
Gregk
  • Loc: San Tan Valley, Az,
Posted 25 December 2012 - 03:50 PM
Hi
I want to buy a tablet and run skyeye or sky safari so I can hold it up to the sky in real time and see alignment stars
Can you just add your location or do you need gps I assume the gravity sensors would work with just a zip code or location in the setup menu Just want to make sure
Greg
#2 Starman81
Starman81
  • Loc: Metro Detroit, MI, USA
Posted 25 December 2012 - 04:14 PM
Hi
Greg
I use SkySafari Pro on my iPad and Android phone... You can definitely input your location, but most tablets (iOS or Android), if not all, have GPS built-in.
#3 Jon Isaacs
Posted 25 December 2012 - 06:52 PM
Hi
Greg
Greg:
I am not sure about Skeye but you can certainly add locations manually with Sky Safari. If you are looking for an inexpensive tablet, to run Sky Safari, make sure that it has access to the Google Playstore, some do, some don't. If you get one that doesn't then you won't be able to download Sky Safari.
#4 Gregk
Gregk
Posted 25 December 2012 - 07:45 PM
Thanks for the replies Looks like Ipad mini or Galaxy 2 10inch
both have sensors I believe
#5 Sean Wood
Sean Wood
  • Loc: North Carolina
Posted 26 December 2012 - 08:16 AM
Yes you can add you location into either app manually, so you really don't NEED GPS built in. Though if you're wanting to use it as a virtual star finder the device you get WILL need to have either a Gyroscopic sensor OR a combo of Magnetometer and Accelerometer. Either of the the 2 devices you mentioned have that covered.
#6 Spaced
Spaced
  • Loc: Tacoma, Washington, USA
Posted 26 December 2012 - 11:41 PM
Research the iPad Mini carefully before you buy. Mine has a compass but it does not have GPS. I believe (not certain!) that's presently true of all Minis. Incidentally, FWIW, I love mine.
#7 skysurfer
skysurfer
  • Loc: NL, N 52 E 6
Posted 27 December 2012 - 07:17 AM
I have both but Skysafari is way better than Skeye.
Even the 'Lite' version ($3) already is better.
#8 Gregk
Gregk
Posted 30 December 2012 - 12:10 AM
Sensors Ipad Mini
Three-axis gyro
Accelerometer
Ambient light sensor
Looks like LTE version has GPS
