Comet C/2011 L4 (PANSTARRS)
724 replies to this topic
#26 Tonk
Tonk
  • Loc: Leeds, UK, 54N
Posted 01 February 2013 - 12:39 PM
Even better ones here
http://cometchasing.skyhound.com/
and here
http://www.shopplaza...mets/comets.htm
#27 Centaur
Centaur
  • Loc: Chicagoland
Posted 01 February 2013 - 01:19 PM
It's now Feb. the Moon is slowly going away I'm waiting for another obs.
Comet C/2011 L4 (PANSTARRS) will reach its maximum southerly declination of 45.6° on 2013 FEB 05 where it is essentially out of sight for observers well north of the tropics. However it will soon be headed northward as the charts and ephemeris on my comets webpage indicate: www.CurtRenz.com/comets
During late February the comet will appear to pass the first magnitude star Fomalhaut. The separation will be only 2.5° on February 26. Unfortunately the Sun will also appear in the vicinity. Below is an equatorial chart I created to illustrate the close approach.
#28 pogrzex
pogrzex
Posted 02 February 2013 - 05:58 AM
Hi, of course I know about March visibility. I had rather in my mind another southern hemisphere observations confirming or denying this very weak 3 magnitude...
#29 BrooksObs
BrooksObs
Posted 02 February 2013 - 08:46 AM
It would appear that all the most recent incoming photometric data on PanSTARRS only serves to confirm the recent (not unanticipated) reduced rate of brightening. As of yesterday morning the comet was reported as of magnitude 6.5 with a 6' coma and a 0.2-degree, slightly curving, dust tail directed toward the NW.
Once again re-evaluating the growing body of photometric data ths morning and using 26 selected observations spanning Jan. 01 to Feb 02 results in the formula:
m1 = 5.6 + 5 log(D) + 6.6 log r
implying a maximum brightness of no more than +2.0
BrooksObs
#30 Tonk
Tonk
Posted 02 February 2013 - 01:05 PM
Its been a while since a mag +2 comet anyway so I wont sniff at that.
#31 Special Ed
Special Ed
Posted 02 February 2013 - 01:45 PM
Yep. :)
#32 pogrzex
pogrzex
Posted 03 February 2013 - 03:53 AM
Consider that +2 mag is now optimistic scenario.
#33 Ptarmigan
Ptarmigan
    Lagopus lagopus
  • Loc: Arctic
Posted 04 February 2013 - 09:13 PM
I would not laugh at a magnitude 2 comet either as they are rare as well. Comets are hard to predict.
#34 pogrzex
pogrzex
Posted 06 February 2013 - 07:48 AM
Hey, the comet is now making nice gas tail. What does it mean for us?
http://spaceweather....60123770_lg.jpg
#35 Dave M
Dave M
  • Loc: Ohio
Posted 06 February 2013 - 09:21 AM
I`ll take a mag 2 comet any day of the week :)
#36 BrooksObs
BrooksObs
Posted 06 February 2013 - 11:33 AM
Probably nothing very heartening, I'm afraid. Were PanSTARRS a more active comet one would have anticipated the development of an ion tail significantly early than this. In fact, there apparently still wasn't a detectable one even as late as last week! By way of comparison look at the ion tail on Comet Lemmon which is more typical of a type I tail (and has been present for some time) while currently at 1.2 a.u. from the Sun. Then compared that with PanSTARRS', with that comet at 0.91 a.u. Pretty darn weak, I'd say.
Likewise, the latest observations would seem to indicate that the comet's brightness may be beginning to fall behind even that predicted by the magnitude formula I had posted up-stream, making the prediction of a peak brightness of +2.0 in mid March ever less likely.
BrooksObs
#37 azure1961p
azure1961p
  • Loc: Triton
Posted 06 February 2013 - 09:57 PM
What magnitude was hale-Bopp or hyakutake?
Pete
#38 BrooksObs
BrooksObs
Posted 06 February 2013 - 10:44 PM
Pete
At their peaks, -0.5 and 0.0 respectively.
BrooksObs
#39 azure1961p
azure1961p
  • Loc: Triton
Posted 06 February 2013 - 10:48 PM
Ok - thanks.
Still 2+ is impressive in my book. Very-good is entirely acceptable . Frankly anything brighter mag 6 to me is good so this ought to be refreshing.
Pete
#40 pogrzex
pogrzex
Posted 07 February 2013 - 02:17 AM
What significance does it have? They were visible on dark sky easily with naked eye. There is no chance to see +2 mag object with naked eye so low over the horizon + on so bright sky. To me it's no comparison!
#41 Tonk
Tonk
Posted 08 February 2013 - 06:45 AM
Its called a washout!
#42 BrooksObs
BrooksObs
Posted 09 February 2013 - 09:48 AM
A new analysis of selected visual photometric data spanning Jan 7 to Feb 9 results in the following magnitude formula:
m1 = 5.6 + 5 log(D) + 6.7 log® , cc = 0.93
The fit to the data is excellent and it is noted that these parameters are hardly any different from those derived a week ago, suggesting that these terms are becoming quite certain now. They are also rather similar to those derived for Comet Kohoutek back in 1974. Descriptions using binoculars and small telescopes continue to indicate a bright pseudo nucleus within the coma and a short but obvious and rather dramatically curved dust tail, with the ion tail almost absent.
Considering our viewing geometry in mid to late March the above implies an ever more probable peak magnitude of close to +2.5 with the comet displaying a broad, highly curved tail, perhaps of rather low surface brightness which will have reduced visibility particularly when viewed at low elevation against a twilight backdrop.
BrooksObs
#43 Jure Atanackov
Jure Atanackov
Posted 09 February 2013 - 11:08 AM
So, something similar to C/2002 V1 (NEAT) in the second week of Feb 2003...
Mr. Bortle, what do you think about comet Kohoutek's return to a higher n at log® < -0.6? Would it be reasonable to expect something similar from PanSTARRS?
http://www.lesia.obs...11l4-2012s1.jpg
Clear skies!
Jure
#44 BrooksObs
BrooksObs
Posted 10 February 2013 - 08:28 AM
Jure, while a possibility I would tend to think it is more likely that Comet PanSTARRS' post perihelion behavior will be rather different from Kohoutek's by virtue of PanSTARRS' very high dust production rate. In constrast, Kohoutek showed a strong ion tail, which has been so far very weak in PanSTARRS, and only a modest dust tail (except when very near perihelion) for a comet with such a small perihelion distance. This would imply a marked difference in composition, reflected in the gas vs. dust production ratios of the two objects. PanSTARRS so far seems to be a very dusty comet (particularly "heavy" dust at that).
I would also note that, in my opinion, total magnitude determinations when a comet is further than 2.5 a.u. from the Sun should be regarded as increasingly suspect, particularly those made during the post-T interval, for a number of quite valid reasons.
BrooksObs
#45 Phillip Creed
Phillip Creed
    Idiot Seeking Village
  • Loc: Canal Fulton, OH
Posted 11 February 2013 - 03:32 PM
One thing the low elevation of C/2011 L4 does remind me of is whether or not the ICQ extinction tables/method needs updating.
There are tables provided for altitude to every 0.5 km to account for Rayleigh scattering and the 0.016-mag/air mass extinction for ozone is essentially "baked into the cake".
It's the aerosol extinction, though, that perhaps needs a makeover. There are three tables to account for various aerosol loads ("average", "winter", and "summer"), with the "average" set at 0.120-mag/air-mass and the winter and summer values set at 70% and 130% of that, respectively.
There are multiple issues I've got with this approach. (1) The "winter" extinction table can be used year-round at desert locations and most of Australia, and even that doesn't account for how clean the air can be in these locations. Likewise (2) some locations with humidity and high industrial emissions rarely have clean enough air to justify the "average" extinction table, and (3) the aerosol extinction is assumed to decrease logarithmically with altitude. Normally that's the case, but there could high-altitude haze (e.g. forest fire smoke, volcanic ash) that might be absent from the lowest 10,000-ft altogether.
Aerosol extinction, in other words, simply is what it is for a particular location and time. The only way to really account for it in your estimate is to compare the brightness of stars low along the horizon with those near overhead and to back-calculate the aerosol (and, thus, total) extinction if--IF--an estimate needs to be corrected for atmospheric extinction. It'd be very cumbersome to put it in tabular form, but a simple spreadsheet program with a few inputs would easily suffice.
Obviously an experienced comet observer should go out of his/her way to seek out suitable comparison stars at similar altitudes as the comet to avoid the use of extinction tables altogether, but some comets take away that option from the get-go. And I'd concede that the methodology of the observer can easily introduce as much error and uncertainty as atmospheric extinction to begin with. It's just something that's bothered me for some time, and the low elevation of C/2011 L4 at its brightest just reminds me of it. This isn't meant to be a slight to Dr. Green's very important and well-researched 1992 ICQ article regarding atmospheric extinction; quite the opposite. Maybe it's time to update to procedure a bit by tailoring the equations to specific conditions and locations.
Clear Skies,
Phil
#46 Phillip Creed
Phillip Creed
Posted 11 February 2013 - 03:39 PM
For those interested in Dr. Green's article on atmospheric extinction, see:
http://www.icq.eps.h...ICQExtinct.html
Clear Skies,
Phil
#47 BrooksObs
BrooksObs
Posted 16 February 2013 - 09:29 AM
Updating the comet's photometric parameters to include this week's reported observations from select southern hemisphere observers suggests a possible slight up-tick in the figures. However, it must at the same time be appreciated that the comet can now only be observed at extremely low altitude in the morning sky in brightening nautical twilight. Data spanning 2013 Jan 7 to Feb 16 results in the magnitude formula:
m1 = 5.6 + 5 log(D) + 7.1 log® cc = 0.97
If carried to perihelion this implies a peak magnitude of 2.1 as seen from the Earth during mid March.
Reports of the comet's appearance as seen with with small instruments and binoculars this week indicates the head to be extremely condensed and the typical double tails (ion and dust) are now both apparent and photographically of almost equal length.
BrooksObs
#48 krp
krp
    Vendor. DarkSiteFinder.com
  • Loc: Central Illinois
Posted 16 February 2013 - 08:55 PM
What will be the best time to photograph C/2011 L4? Is the tail likely to grow after perihelion as the comet dims? Even though it will be at its brightest 3/9 I'm just wondering if it will be more photogenic after that as it moves away from the horizon and the tail possibly grows.
#49 SabiaJD
SabiaJD
  • Loc: Clarks Summit, PA
Posted 17 February 2013 - 11:33 AM
You will require a unobstruted western horizon. It will set soon in twilight close to the crescent Moon on 12 March 2013. I am expecting dimming of the tail by moonlight and distance above the horizon.
Comet will be in twilght skies. Would like to see it in darker skies, but appreciate any view I can get of this comet in the March skies. Expecting clouds on the horizon to be a hinderence.
#50 BrooksObs
BrooksObs
Posted 17 February 2013 - 05:10 PM
KRP - John Sabia is quite correct in his post. The fact is that there is a distinct possibility there won't be a time when the comet's tail will be easily viewable, or can be photographed to real advantage, before it fades.
The head of Comet PanSTARRS will be seen only very low and in the western twilight well into April for mid northern latitude observers, by which time C/2011 L4 will have faded considerably. At the same time odds are that the comet's bluish ion tail could prove difficult to recognize, particularly visually, in the intense twilight. The brighter and more visually apparent dust tail is likely to initially be directed toward the southeast at a low angle and largely subdued by the bright sky. The latter appendage may likely not be seen to project more-or-less upwards in classic comet fashion until fairly late in March, by which time the moon, then in its gibbous phase, could severely hamper any visibility.
So, astro photographers are likely to be faced with a catch as catch can senario, attempting to trade off comet altitude, favorable tail direction, twilight and moonlight interference to gain any impressive images.
BrooksObs
