C8 Grounding question
70 replies to this topic
#1 orion61
orion61
  • Loc: Birthplace James T Kirk
Posted 05 January 2013 - 07:58 AM
I have an early Sandcast C8 but it only has a 2 prong plug,my
others have the 3 prong shielded cable, I use a drive converter but we are still at 110V AC. outside in dewy grass, Am I going to electrocute myself?
#2 dgreyson
dgreyson
  • Loc: South Carolina
Posted 05 January 2013 - 10:57 AM
oh Phui!! Man up! Touching your eye to a metal telescope thats wet with dew while standing on a good earth ground?? If your lucky you may just be severely injured.
The synchronus motor windings can overheat, swell up, short against the motor casing and connect 110 volts to the frame.
I doubt the telescope is double grounded if the gears are metal so a three prong plug is better than none. If you need to keep the integrity of your scope as is, just use a Ground fault interrupter extension cable. If you ever get your drive corrector working, you are safe if using a car battery as the power source because the output is isolated and so isnt referenced to ground like line voltage is. If you use the same AC socket, have it changed out to a gfi socket like they put in the bathroom and you can use a regular extension. You still can get a nasty shock until the gfi trips but it should interrupt the current before it gets lethal. ME, I'd use a 3 prong cord and a GFI, but that's only because I seriously plan on outliving my dog.
Notice: this does not constitute qualified advice and should be considered as hearsay and rumour. your mileage may vary. This product is meant for educational purposes only. Any resemblance to real persons, living or dead is purely coincidental. Void where prohibited. Some assembly required. List each check separately by bank number. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Postage will be paid by addressee. Subject to approval. This is not an offer to sell securities. Apply only to affected area. May be too intense for some viewers. Do not stamp. Use other side for additional listings. For recreational use only. Do not disturb. All models over 18 years of age. If condition persists, consult your physician. No user-serviceable parts inside. Freshest if eaten before date on carton. Subject to change without notice. Times are approximate. Simulated picture. No postage necessary if mailed in the United States. Breaking seal constitutes acceptance of agreement. For off-road use only. As seen on TV. One size fits all. Many suitcases look alike. Contains a substantial amount of non-tobacco ingredients. Colors may, in time, fade. We have sent the forms which seem to be right for you. Slippery when wet. For office use only. Not affiliated with the American Red Cross. Drop in any mailbox. Edited for television. Keep cool; process promptly. Post office will not deliver without postage. List was current at time of printing. Return to sender, no forwarding order on file, unable to forward. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. At participating locations only. Not the Beatles. Penalty for private use. See label for sequence. Substantial penalty for early withdrawal. Do not write below this line. Falling rock. Lost ticket pays maximum rate. Your cancelled check is your receipt. Add toner. Place stamp here. Avoid contact with skin. Sanitized for your protection. Be sure each item is properly endorsed. Sign here without admitting guilt. Slightly higher west of the Mississippi. Employees and their families are not eligible. Beware of dog. Contestants have been briefed on some questions before the show. Limited time offer, call now to insure prompt delivery. You must be present to win. No passes accepted for this engagement. No purchase necessary. Processed at location stamped in code at top of carton. Shading within a garment may occur. Use only in well-ventilated area. Keep away from fire or flame. Replace with same type. Approved for veterans. Booths for two or more. Check here if tax deductible. Some equipment shown is optional. Price does not include taxes. No Canadian coins. Not recommended for children. Prerecorded for this time zone. Reproduction strictly prohibited. No solicitors. No alcohol, dogs, or horses. No anchovies unless otherwise specified. Restaurant package, not for resale. List at least two alternate dates. First pull up, then pull down. Call toll free before digging. Driver does not carry cash. Some of the trademarks mentioned in this product appear for identification purposes only. Record additional transactions on back of previous stub. Decision of judges is final.
This supersedes all previous disclaimer notices.
#3 apfever
apfever
  • Loc: Colorado
Posted 05 January 2013 - 11:56 AM
nice disclaimer. No comment.
#4 desertrefugee
desertrefugee
  • Loc: Arizona
Posted 05 January 2013 - 03:21 PM
"Not the Beatles" !??
Then forget it.
#5 Littlegreenman
Littlegreenman
  • Loc: Southern California
Posted 05 January 2013 - 04:44 PM
Maybe someone knows if running it offer a battery pack reduces any shock or electrocution risk?
Disclaimer This posts has no disclaimers.
LGM
#6 desertrefugee
desertrefugee
  • Loc: Arizona
Posted 05 January 2013 - 05:56 PM
LGM
120VAC is still 120VAC - even if it has been inverted from 12VDC. Power delivery varies by inverter, but in general, most of the same cautions should apply. There's no current limiting in place and the unit will deliver until the fuse/breaker terminates the circuit.
As little as 10mA to the heart will stop it. That's not a lot of current. Given perfect (or imperfect) conditions, moisture, point of application, electrocution could occur.
No disclaimers. Just casual observations by one who works in the cardiac rhythm management business.
#7 orion61
orion61
Posted 05 January 2013 - 06:06 PM
I have a newer base I could pull the forks off and mount it on that. It is 3 prong, and I wouldn't mess with the origonal base, I couldn't deface it! I'm a huge fan of restoring these old beauties, as a matter of fact I am doing one right now for a friend..
PM for details.. there is a thread about it around here somewhere...LOL
#8 dgreyson
dgreyson
Posted 05 January 2013 - 06:36 PM
Cool, I feel the same, If its something vintage, Id rather have it factory original. Except for my corvette, I had that *BLEEP* tricked out for speed. It got 12 mpg but it would blow the doors off of anyone elses heap. when gas went above 35 cents a gallon I had to reluctantly sell it coz it was taking all my beer money.
As far as Electric shocks go, Wall voltage is different from inverted voltage. Household current is one leg of a 220v circuit that is referenced to earth ground. If you touch the hot lead, current will flow thru you to the ground and shock you. it only takes a single wire. Ive also gotten shocked from the neutral lead as well, dunno why. (used to know but forget) If you touch one leg of an inverter generated circuit, wou shouldnt be electrocuted because it "Floats" above the earth ground. You would need to touch both legs of the inverter output to make a circuit that current could flow through. Thats why I said it was Safer. you would need to bridge across the output to get a shock while AC line will kill you if you touch just one wire or the circuit has a short to the casing. If one side of the inverter output shorts to the casing, you likely would not feel a shock. I'd say you couldnt except I stopped saying absolutes when the second space shuttle blew up. Anything can go wrong.
see legal disclaimer above.
#9 Littlegreenman
Littlegreenman
Posted 05 January 2013 - 07:50 PM
LGM
Thanks for the reply. Now I know.
I think I'll get a gravity driven clock drive...
SL
#10 dgreyson
dgreyson
Posted 05 January 2013 - 08:50 PM
[quote
[/quote]
You would only mash your toes when you drop a weight and get gangrene. Or you could put your eye out if the mainspring broke or something. No, It's much safer if you get someone else to look thru it and describe what they see to you. You might think that if you stayed home and let them sketch it on a paper and bring it to you that would be safest but your wrong. Because their nasty germs would be on it and you may catch a desperate illness. No no. :roflmao:
#11 orion61
orion61
Posted 05 January 2013 - 09:06 PM
You know if some one could come up with an inexpensive Wind up Clock drive, I'd be ALL over it for general observing!
I'd even try it with go-to... just give me that BIG key
like the Robots in the 50's had in back LOL
I'm serious tho about having a visual mount with a mechanical clock drive.. they could be made...
#12 johntrob
johntrob
  • Loc: Georgia, USA
Posted 05 January 2013 - 10:05 PM
Remember the old refrigerators, grab the handle and get a charge, still alive.
#13 dgreyson
dgreyson
Posted 06 January 2013 - 12:00 AM
we had an old metal chest freezer on the concrete carport slab and if you forgot you were barefoot and grabbed the handle to get something it would knock the fool out of you.
I'm sure it could have killed someone under the right conditions, say wet concrete. The adults never knew it of course because they always wore shoes. But it was nowhere near the shocks I used to get from Microphones when I was in a band and they had the amp plugged in wrong so I never thought much about it or told anyone. Just part of doing business I guess.
#14 dgreyson
dgreyson
Posted 06 January 2013 - 12:03 AM
I wonder how troublesome the mechanical drives were on Unitrons? they used weights on a chain like a grandfather or a cukoo clock.
here is a thread about them
mechanical clock drives - post a picture
#15 actionhac
actionhac
  • Loc: Seattle
Posted 06 January 2013 - 12:48 AM
It wouldn't hurt to ground our 110V drives.
Its surprising how easy it is to kill one's self.
I guess we don't think of the danger because we can't see it.
We can buy a appliance cord with a 3prong plug and connect white-white, blk-blk, and ground the green to the drive motor mounting bolts.
Or a 6ft 3prong extension cord and cut off the female and hard wire it in the same as above.
I know its not original but it may save a life under the right circumstances.
Have I done it myself? no I haven't! I'm so lazy. No that's not really it I'm a real stickler for originality is the real reason and yes it will be chiseled onto my tombstone no doubt.
I've been shocked many times, I work with electricity in my job. Sometimes its just a little tingle and other times it has left me with a sore arm. A few times I blinded myself for the rest of the day.
Robert
#16 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 06 January 2013 - 11:41 AM
I just checked my two old sand cast C-8 mounts with the two prong Jones plug. There is Continuity between the motor housing and the unpainted back of the mount, but none to any painted section of the mount.
While the paint is not a perfect solution it does provide some protection.
A simple solution is to make up a new cord using a three wire grounded plug. At the Jones plug, pull out the green grounding wire and attach it to one of the screws that hold the male Jones plug into the mounting base. Now the scope is grounded as long as you use a grounded outlet with hopefully a GIF on it.
I also have Criterion RV-6 and when I restored in many years ago, I replaced the original cord with a three wire molded one and attached the ground wire to one of the bolts on the motor mount.
- Dave
#17 tim53
tim53
  • Loc: Highland Park, CA
Posted 06 January 2013 - 12:56 PM
a couple years back, I bid on a drive base for a 70s C8 that was made by Optica b/c, IIRC. Very cool unit with a worm drive. Though not original to the scope, it was of the same vintage. Kind of like one of those retrofits to the C-14 drive made by Ed Byers, only this one was entirely non-Celestron manufacture.
I'm pretty sure it was 110V, though :crazy: Matters little, as I lost the bidding. :(
-Tim.
#18 PiSigma
PiSigma
  • Loc: North Carolina
Posted 06 January 2013 - 12:58 PM
In order to keep my scopes original (two prong plug, ungrounded) and safe I have made up a cord with just the ground wire at the AC plug and an alligator clip on the other end. I run a grounded extension cord and power strip to the scope and plug the scope and my extra ground lead into the strip, then clip the alligator clip to the scope's motor housing. Everything is then grounded and originality maintained.
#19 tim53
tim53
Posted 06 January 2013 - 01:08 PM
Does anyone know of DC servo motors that wouldn't need more room than the stock Synchronous motors in the C-8 drive base?
Because, if there are, and they have encoders built in like the Pittmans (which are too big to fit the space in a Celestron drive base), I could imagine converting one to goto with all the cool software like PointXP that comes with the Sidereal Technology goto kit. Within wide limits, you can set the drive rate for specific gear ratios in software.
I did this with my Tak Em-500 mount for about a year or so before Dave Groski repaired the original non-goto controller for me (that I'd fried an IC on because I thought ALL Taks were 24V, but the old ones weren't). Worked very well, though I never used the goto feature because I used the mount for planetary only at the time. Still have the Sitech kit to put in/on another mount, but I'll probably put it on the big Springfield mount I bought a few years ago, which has no drive as yet (no motors, that is, it's got an 11" RA gear!).
I don't like dying before I'm spent, and I'm hoping that's going to be a long time from now. You guys are scaring me about these old AC drives, now. I wouldn't be averse to converting a classic to a DC system if (and only if) it could be completely reversible. Bolt-in only for me for some of these old scopes. If I made such a conversion, I'd keep the original parts - kind of like we keep those screw in sun filters that come with our classic refractors - so everything could be put back to original as the scope's value increases to warrant that.
-Tim.
#20 orion61
orion61
Posted 06 January 2013 - 01:14 PM
I remember as a Kid we used to have a lawn Mower with a big wind up crank that would turn the motor over when released.
It worked great i wonder why they stopped making them..
We have a Clock maker/Repairman who still works on the old time clocks,pocket watches and anything with gears.
I ownder if he could think of something. I'll bet
there would be a market in the Classifieds for us old timers that would appreciate such crafstmanship!
I know I would buy one in a heartbeat..
#21 actionhac
actionhac
  • Loc: Seattle
Posted 06 January 2013 - 04:22 PM
Our mower had that feature. Wind it up, stand back, push the button. Pretty scary like starting the red baron's fighter plane, wild and crazy. Very reliable though, no rope to break. I remember it well. It was a vertical shaft engine so I couldn't use it on a go-kart, too bad.
TASCO sold a wind-up. 20min run time. #1602-M Look in here:
http://geogdata.csun...o/tasco1968.pdf
YOU CAN BUY "portable" GFI protection as a strip or built into a extension cord like here:
http://www.cpsc.gov/...ub/pubs/099.pdf
Robert
#22 dgreyson
dgreyson
Posted 07 January 2013 - 09:43 AM
Home depot has a $30, 2 foot long Ground fault extension cord you plug into the wall socket and then plug a regular extension into. As long as you have a 3 prong outlet to plug the GFI adaptor into, it protects you from shocks even if your drive adaptor is 2 prong. Lowes and walmart also sell them.
#23 Geo.
Geo.
  • Loc: Upstate NY
Posted 08 January 2013 - 05:30 PM
In Australia clocks run on 240v. Here's a link to a discussion and some options to deal with old AC motors:
http://sound.westhos...clocks/ocm.html
#24 dgreyson
dgreyson
Posted 08 January 2013 - 08:14 PM
That means that If you grab hold of a shorted telescope and you get hit with 220 volts, you would shortly be "Down under" :foreheadslap:
#25 rmollise
Posted 09 January 2013 - 09:17 AM
- Dave
This will do it, and is maybe not a bad idea...with a couple of caveats:
1. If you are inexperienced with electrical work, leave it alone. If you simply must have a three prong cord on your C8, have someone who knows what they are doing install it. Some famous last words: "Nothing to it." ;)
2. I do not recall ever hearing, over the past 43 years, of anyone being electrocuted by a dadgum C8. :cool:
