Hyper Tuning My CGEM DX
4 replies to this topic
#1 TimP
TimP
  • Loc: Columbus, Ohio
Posted 05 January 2013 - 09:49 PM
Hello all. Long time lurker first time poster. I am in the middle of Hyper Tuning my CGEM DX. I pulled the motors out and gave them a few rotations in both directions. The RA motor turns fine in the clock wise direction but when I rotate it in the counter clock wise direction it has a sticking point every once in awhile. There is no sticking of the Dec motor. Heres the question. Do you think I should swap the RA and the DEC motors or should I search for another motor for the RA ?
Tim Patton
#2 mak7
mak7
  • Loc: light polluted Phoenix AZ
Posted 06 January 2013 - 07:44 PM
Tim,
First thing I would do is email Ed Thomas at Deep Space Products and ask his opinion on a solution. He has been through many, many mounts and knows all the fine tuning they need.
Ed is a straight shooter and will give you his honest opinion. I assume you purchased a HyperTune Kit from him, so he will be happy to work with you.
Brad
#3 TimP
TimP
Posted 06 January 2013 - 08:49 PM
Thanks Brad
I powered the motor and it doesn't have a sticking point that I can see. I'll put it back in and see how it acts after the rebuild. Frankly as tight as the worm gears were I should be surprised if it doesn't have motor problems. When I removed the clutches the mount didn't move. I had to manually move it. Good ole Chinese quality control. But this is what I have to contend with in my price range.
#4 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 06 January 2013 - 11:22 PM
That's probably the best thing to do first since it is easy to remove the motors at any time. See how this one does, if it seems to be problematic, then I would recommend getting a replacement from Celestron but it may be fine as it is.
#5 TimP
TimP
Posted 06 January 2013 - 11:35 PM
Thanks Ed. Everything is going great so far. I had to stop working on the mount until I get a tool I need to take off the end caps to the worm gear. This is my second mount. Celestron exchanged the first one because they couldn't figure out the problem. As I take this one apart it almost looks like someone has taken it apart before. Hmmm, I guess you never know.
