Tri-pod or pier
5 replies to this topic
#1 JR#8
JR#8
  • Loc: Edison, NJ
Posted 06 January 2013 - 08:16 PM
Looking to get a wedge for my 10" lx200 SMTGPS. I'm wondering if it will work well with the field tri-pod or should I look to builg/get a pier. Looking for the least vibration possible.
#2 dmdouglass
dmdouglass
  • Loc: Tempe, AZ
Posted 06 January 2013 - 09:26 PM
Least vibration would point you to a well configured pier.
By that, i mean a pier with adequate diameter (in this case i would suggest 1' dia), and a good strong, deep, wide base.
The fact that you are considering a pier, suggests that this is going to be a "fixed" location.
#3 Rick Woods
Rick Woods
  • Loc: Inner Solar System
Posted 06 January 2013 - 11:48 PM
If you will be moving it around at all, look for a Meade Giant Field tripod. Weighs about 50 lb, has 4" legs, and is *really* solid. I used my 14" on a Superwedge on this tripod for a couple of years. Next best thing to a pier!
But if you have a permanent place, do a 12" concrete pier.
#4 JR#8
JR#8
  • Loc: Edison, NJ
Posted 07 January 2013 - 07:07 PM
i forgot to say i would like it to be portable
#5 Rick Woods
Rick Woods
Posted 07 January 2013 - 08:07 PM
Then I *really* advise the big Meade tripod. (Not the one that comes standard with the 10" SCT!) A heavy-duty, precision wedge is a good idea, too. Don't get a Superwedge; they work great, as long as you don't have to adjust them; but Mitty or Milburn make state of the art, fine-adjustable wedges.
I've never tried a portable pier; but it seems like it wouldn't be as stable as a tripod. And with a tripod, you can also use a scope buggy!
And don't forget the vibration suppression pads for the tripod legs. Those even worked on my 14" w/wedge and all - right about 250lb of weight, and I could still tell the difference with the pads! (That much weight ended up mushing them down pretty good, though.)
#6 JR#8
JR#8
  • Loc: Edison, NJ
Posted 07 January 2013 - 08:17 PM
thanks for the info That makes alot of sence
