What is this?
10 replies to this topic
#1 ptsouth97
ptsouth97
Posted 06 January 2013 - 10:37 PM
Can someone please help me identify what this piece is? It came with a used Celestron C8 I recently bought. The guy I got it from doesn't know either. It is a right angle bracket that has a screw which fits a camera. Also, it has a single small circular bracket with three screws, kind of like for a finderscope. I thought maybe it was for holding a camera near the eyepiece for afocal photography, but that doesn't seem to fit. Any help would be greatly appreciated.
#2 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 07 January 2013 - 05:24 AM
Looks like something to hold a laser pointer, but I'm just guessing.
#3 snowcrow
snowcrow
  • Loc: Vermont
Posted 07 January 2013 - 06:06 AM
I think it's an Afocal adapter. Can the bracket with the three screws slip over an .965" eyepiece? If so, thats what it is.
#4 ptsouth97
ptsouth97
Posted 07 January 2013 - 07:02 AM
I was thinking afocal adapter, too, but there's not nearly enough clearance to use a DSLR, so it would have to have been designed exclusively for small, non-dslr cameras.
Laser pointer holder makes sense, too, except I'm not sure what it would attach to given the direction of the screw.
#5 junomike
junomike
  • Loc: Ontario
Posted 07 January 2013 - 03:28 PM
Laser Pointer/Finder for Binoculars?
#6 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 07 January 2013 - 04:07 PM
Ewwwww, whatever it is, put it down, you don't know where its been.......
#7 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 07 January 2013 - 06:36 PM
I don't think it's an afocal adapter for a small pocket camera because it doesn't have a 2-axis adjustment.
[Note: Since many of these small cameras are fully manual and have chips as large as 14Mp, it's no longer necessary to use a DSLR for photography of this kind. In fact, DSLRs are darned difficult to use for afocal photogrqaphy unless you have eyepieces that allow the attachment of your camera body (like Baader Hyperions, for example).]
I think it is a finder bracket for a small finder and the extended part with the screw in it attaches the finder to a dovetail bar or a camera adapter on the back of an SCT. It could hold a laser, but might just as easily be a small optical finder.
#8 Eddgie
Eddgie
Posted 07 January 2013 - 07:01 PM
Looks a lot like an afocal camera holder to me.
First, it has a 1/4 - 20 thread facing up. This would indicate that a camera is destined for the plate the screw sits in.
There is a slot on the "eyepiece" holder piece which would allow the eyepiece holder to be moved vertically to bring the camera to the right height.
Since the threading of the 1/4 - 20 screw points "Up", there would be no way to mount a finder or something on a telscope body, and why would there be a slot to adjust the height?
Looks like a duck, quacks like a duck, must be a duck.
And this looks and quacks like an afocal camera holder, so that gets my vote.
#9 Starman1
Starman1
  • Loc: Los Angeles
Posted 07 January 2013 - 08:35 PM
Since the threading of the 1/4 - 20 screw points "Up", there would be no way to mount a finder or something on a telescope body, and why would there be a slot to adjust the height?
1. every brand of camera has its mounting hole placed differently on the bottom. There would need to be a lateral piece (another axis) to put the camera lens in front of the eyepiece.
2. You assumed the knob and screw were put into the holder accurately. It could just as easily mount in the other direction.
3. The slot would adjust the position of the eyepiece for the finder.
Frankly, though, I agree with you but I think there is a piece missing that would allow the camera to be adjusted perpendicular to the slot.
#10 ptsouth97
ptsouth97
Posted 08 January 2013 - 11:57 PM
Thanks to everyone for your help. I'm leaning towards afocal adapter at this point. Upon closer inspection, there is a screw that loosens to allow adjustments perpendicular to the slot. If you look in the picture, you can see the channel where it slides. Also, I noticed that the inside of the circular piece with the 3 screws is threaded, as if it can accept an adapter of some sort.
#11 Doc Bob
Doc Bob
  • Loc: Maryland, USA
Posted 09 January 2013 - 06:10 PM
. . . looks like a bracket for a "specific" make of camera (who knows what brand) - since the only adjustment is for the distance to/from an eyepiece. I pretty much agree with Don P . . .
Bob
