Tiles tear off please help
9 replies to this topic
#1 Rockâ„¢
Rockâ„¢
Posted 08 January 2013 - 06:04 AM
Hi 2 hours ago i was grinding my 8" F6 mirror, process was going fine then suddenly my son show me that 4 tiles are wearing off and red color brick like material is coming out behind the smooth face of tiles. It looks to me that smooth face of tiles is wearing n tearing off.
This is very looking like bricks. I am using ceramics tiles.
Coach me friend, what should i do now and my camera is also damaged otherwise i shows u all the image.
#2 planet earth
planet earth
  • Loc: Canada 43*N 80* W
Posted 08 January 2013 - 06:15 AM
I believe you are using the wrong type of tiles.
Porcelain tiles are ther ones that you want or unglazed ceramic.
Willman Bell sells a sq ft for $9.00
Sam
#3 dave brock
dave brock
  • Loc: Hamilton, New Zealand
Posted 08 January 2013 - 07:09 AM
I don't think you need to worry if the surface is just grinding off, that's normal. I've used tiles like that many times without problems.
Dave
#4 planet earth
planet earth
Posted 08 January 2013 - 11:33 AM
Dave
I found that some cheaper glazed tiles use a soft ceramic, but yes if you wear off the glaze and ceramic is good quality they are fine.I like the Willman Bell unglazed tiles at $9.00 a sq ft.
Sam
#5 mark cowan
mark cowan
    Vendor (Veritas Optics)
  • Loc: salem, OR
Posted 08 January 2013 - 03:10 PM
You have glazed clay tiles and once the glazing wears off they don't really work, sadly, as the brick-like stuff isn't hard enough. :( You want ceramic tiles which are essentially glazed all the way through.
Best,
Mark
#6 dave brock
dave brock
Posted 08 January 2013 - 03:19 PM
Hi Sam and Mark.
Rock says he is using ceramic tiles so I've taken him at his word. The ones I use have a glazing on the surface which wears off but under that is still very hard and I've had no problem with chipping, scratching etc.
Dave
#7 mark cowan
mark cowan
  • Loc: salem, OR
Posted 09 January 2013 - 12:04 AM
I only said he has glazed tiles because I tried some many years ago and had exactly that experience - once the glaze wore through they were useless.
Best,
Mark
#8 MKV
MKV
Posted 09 January 2013 - 02:35 AM
Rock, try using glass tiles like these. It's best to use clear ones. They also come preattached so they handle like one a sheet, and can be cut to size and epoxied at once. You can buy then in home improvement stores.
Or, as someone already mentioned, buy Willmann-Bell's solid ceramic hex tile. They are very affordable.
Mladen
#9 Rockâ„¢
Rockâ„¢
Posted 09 January 2013 - 03:58 AM
Thanks will try this one out
#10 Pinbout
Pinbout
  • Loc: uhmm...2nd grade
Posted 09 January 2013 - 09:10 AM
but pennies are the cheapest and work really well, and I get less severe zones with them, but I'm spin grinding...
