CES is today... Celestron Edge HD FR?
36 replies to this topic
#26 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 10 January 2013 - 08:17 PM
It looks like I got lucky. I checked my current imaging train and there's a 1" (25.4mm) SCT spacer between the scope and OAG. Which means, replacing the 1" SCT spacer with EdgeHD focal reducer would result only about 3mm over the 105mm required BF. It should work with my Atik 460EX camera. So switching between focal ratios will not complicate changing the imaging train. I just wish it would work with ONAG.
Peter
#27 John Miele
John Miele
  • Loc: North Alabama
Posted 10 January 2013 - 08:45 PM
Patrick,
Is this the Optec reducer model you and Peter are talking about?
http://www.optcorp.c... %0...
I was going to buy this one and I thought it did screw directly to the back of the scope or am I looking at it wrong???
John
#28 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 10 January 2013 - 09:17 PM
I know Optec FR is confusing. It took me a while to figure it out and I exchanged e-mails with Optec and I didn't like their answer.
You screw the FR to the telescope but to connect a camera to FR, you must buy a custom adapter/spacer from Optec to fit in between Optec FR and the camera. One end of Optec custom spacer is a special dovetail connection that connects to FR and other end is a thread to fit your camera. OptCorp web site mentioned "(order Lepus camera mount separately below)" but I don't see their list but you can see them at:
http://www.optcorp.c...ec Lepus HD ...
This one shows a picture of Optec's custom adapter for DSLR. Notice the dovetail at top (set screws).
http://www.optcorp.c...Lepus HD Tel...
Optec FR costs $275 plus about $60 for custom spacer which costs more than Celestron's FR at $300. I suggest Celestron's FR over Optec's.
Peter
#29 Patrick
Patrick
  • Loc: Franklin, Ohio
Posted 10 January 2013 - 11:42 PM
This is a link to the Optec website showing the arrangement. Nice to see an actual drawing of the configuration. HERE
Here's The Webpage for the Camera Mounts
Patrick
#30 Patrick
Patrick
Posted 10 January 2013 - 11:57 PM
I don't think that's a 'dovetail' on the tube side. The three set screws are tightened down into the dovetail on the focal reducer itself. This arrangement allows multiple cameras with different back focus distances to be used with the focal reducer. How is Celestron taking care of this? You will still have to buy some kind of tube to attach to the Celestron f/r. It may not be as expensive, but you'll have to have something. I agree that backing out three set screws to change/remove a camera is not the cleanest solution.
Patrick
#31 Patrick
Patrick
Posted 11 January 2013 - 12:05 AM
That's the one for the EdgeHD 8" that I was talking about. It keeps the focal reducer closer to the back of the scope. Otherwise you'd need a 2" visual back and then put the focal reducer into the visual back.
Patrick
#32 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 11 January 2013 - 12:39 AM
Patrick
That's what I was trying to say. You said it better. I would rather buy my own spacers that use standard threads instead of proprietary dovetails.
Peter
#33 John Miele
John Miele
Posted 11 January 2013 - 01:51 PM
Thanks guys. Ok...I now understand where the dovetail connection is located. It's between the camera adapter tube and the focal reducer bodey.
Well, I went ahead and just ordered the Lepus Edge 8 edition. My reasons were I wanted the larger focal reduction (0.62 vs 0.7), it's available now, and I am using a small chip camera so I don't need the potentially better performance the Celestron model mayhave on a large chip. My total price for the reducer and camera adapter was around $325 shipped with OPT and my rewards. I think the Celestron reducer plus spacer(s) and shipping will run at least the same amount. I'll let you guys know how I like it when it arrives. Good luck to all with the C model. I hope they get it out soon. And thanks for the extra information you provided....John
#34 Patrick
Patrick
Posted 11 January 2013 - 03:02 PM
I'd be more inclined to go with the Lepus myself if I wasn't using a Canon APS-C sensor. I may be buying a midsized mono camera down the road and I think that would work fine with the Lepus.
Let us know how it works for you!
Patrick
#35 bilgebay
bilgebay
  • Loc: Turkiye - Istanbul and Marmaris
Posted 11 January 2013 - 03:14 PM
Although several users reported that AP's CCDT67 didn't work well with C8 and C9 Edge, I am getting excellent frames with it on my C11 Edge. Before buying any FR for my hypothetical C8 Edge, I want to give a chance to CCDT67 on C8 before excluding it from my FR options list. I plan to buy a C8 + Celestron VX mount this summer or fall.
#36 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 11 January 2013 - 04:15 PM
It's very strange how Optec assumes people won't put anything in between FR and camera like OAG and filter wheel. Their adapters connects from FR directly to camera. What if you get a mono camera, filter wheel and OAG, then how are you going to use it with Optec FR?
Why can't Optec make a skinny adapter with one end for dovetail and other end with M42 (T-Thread) or M48 so that we can add more stuff in between adapter and camera using STANDARD threads?
Also, why don't Optec have pictures of their adapters as well as some of their other products? I see "Meade/Celestron 2" SCT-Thread to Optec-3600 Dovetail Adapter" at Opt Corp but I don't understand their explanation and they don't show pictures. Optec has terrible way to show their products by using words instead of pictures. Even at Optec web site says "Photo coming soon" but they usually don't update. What are they hiding?
I am not bashing at Optec. I am sure their optics in FR are excellent, it's the way their FRs are used or connected to other devices that are inconvenient.
Peter
#37 Patrick
Patrick
Posted 12 January 2013 - 01:18 AM
Peter,
I had some communication with Optec today as follows:
"Thank you for your note. We do offer direct sales - I would be happy to
help.
The Lepus telecompressor has a back-focal distance of 100mm which we
maintain with a camera-specific mount. If you can tell me which camera
package (including filter wheel, off-axis guider, etc.) you plan to use
I can make a recommendation."
So, they do take those pieces of gear into consideration. The bottom line for me is that they do not have a large enough full illumination circle for an APS-C sensor. Otherwise, I'm pretty sure they will work fine. I don't think they're hiding anything. They are a big company though and I'd guess these focal reducers are not a high volume product for them.
It could be that the communication problem is less about Optec and more about OPT. I've found out everything I need from Optec. It's been OPT that has not had enough information. Quite frankly, I don't have a dog in this fight, so I could care less one way or the other. I just think it's important to get all the facts out there.
Patrick
