Jupiter 20130105 in SHENZHEN GRS&IO
27 replies to this topic
#1 ZuoZhao
ZuoZhao
Posted 10 January 2013 - 06:26 AM
IO shadow just passed on GRS. I begun capture too late. IO almost left Jupiter. unfortunately, seeing very very poor,not a good result. I took all moons together in processing.They line as the time,from up to low are one,two,three and four.
I use:Skywatcher DOB10+TV5X+ASI120MM
#2 ZuoZhao
ZuoZhao
Posted 10 January 2013 - 06:27 AM
the later one.
#3 Kokatha man
Kokatha man
Posted 10 January 2013 - 06:31 AM
Nice images still despite the seeing smearing detail a bit ZZ..! :waytogo:
#4 ZuoZhao
ZuoZhao
Posted 10 January 2013 - 06:41 AM
Thanks! You are here as me,we have the same daylight. :p
It hard to get a good seeing in winter,even a sunny day. :bawling:
#5 Mert
Mert
  • Loc: Spain, Pamplona
Posted 10 January 2013 - 07:52 AM
I like them very much!!! Especially your first image
is very good with the 4 moons.
Their relative sizes show up very good.
#6 TorstenEdelmann
TorstenEdelmann
  • Loc: Landsberg, Germany
Posted 10 January 2013 - 08:50 AM
fantastic image
You're kidding. I can send you some videos over and I'm sure you'll never use these words again :lol:
Torsten
#7 martus
martus
  • Loc: Czech Republic
Posted 10 January 2013 - 09:27 AM
outstanding!
I would say that you have excellent seeing very often!
martus
#8 Space Cowboy
Space Cowboy
  • Loc: Cheshire, UK
Posted 10 January 2013 - 11:48 AM
I'd be very interested to see a video clip of this poor seeing ;). Lovely images ZZ!
#9 Moey
Moey
Posted 10 January 2013 - 04:14 PM
These are exceptional zuozhao! Very beautiful :)
If you don't mind could you share your workfl
#10 Moey
Moey
If you don't mind could you share your workflow of how you process these?
#11 astrovienna
astrovienna
  • Loc: The NoVa White Zone
Posted 10 January 2013 - 06:05 PM
Poor seeing or not, the moons are very nice.
Kevin
#12 mrlovt
mrlovt
  • Loc: Smyrna, TN
Posted 10 January 2013 - 08:04 PM
Those a great, poor seeing or not. I love the capture with the four moons, very striking!
I need one of those cameras; it seems so much better than my old NexImage!
#13 wenjha
wenjha
    Vendor
  • Loc: SuZhou China
Posted 10 January 2013 - 09:16 PM
Wow!!!!!!!!
I don't know how to descripe my seeing if its poor seeing.
#14 ZuoZhao
ZuoZhao
Posted 10 January 2013 - 10:22 PM
fantastic image
Torsten
I said that,because if seeing became more worse,the AS2 will lost power. Here is an example at same night. It hard to align. And just cant get a result.
#15 ZuoZhao
ZuoZhao
Posted 10 January 2013 - 10:32 PM
No secrets,I think. Since I learn from here ,all steps you can find from here. But some habit will be individuality. If more,my poor English not support me. :bawling:
#16 wenjha
wenjha
    Vendor
  • Loc: SuZhou China
Posted 12 January 2013 - 12:30 AM
speak out of your mind bravely
#17 mrlovt
mrlovt
  • Loc: Smyrna, TN
Posted 12 January 2013 - 03:00 AM
Don't worry about your English, you are doing fine! Your English is much better than my Mandarin, Cantonese, or whatever other languages you happen to speak. =)
I am continually impressed by these Jupiter images with the ASI120 and 10" scope. You have set a good goal for me! Thank you!
#18 sfugardi
sfugardi
  • Loc: CT
Posted 12 January 2013 - 12:07 PM
ZZ, the first image is stunning! To be able to capture every moon and a shadow plus the GRS at such high quality is absolutely incredible. Top shelf all the way. Congradulations and thanks for sharing it
Steve
#19 ZuoZhao
ZuoZhao
Posted 15 January 2013 - 09:07 AM
The later one. Shadow of IO left GRS. Maybe seeing better(even Jupiter low attitude),or telescope match temperature.
#20 MvZ
MvZ
  • Loc: The Netherlands
Posted 15 January 2013 - 09:14 AM
>...It hard to align. And just cant get a result...
You are probably using APs that are way too small and/or not in the correct position. Perhaps you can post a screenshot of AS!2 when you processed that recording? I attached an example of what it more or less should look like.
(Would it perhaps be possible that you send me this blue recording? I'm interested in trying some new things in AS!2 on it)
#21 Freddy WILLEMS
Freddy WILLEMS
  • Loc: Hawaii, Honolulu
Posted 15 January 2013 - 04:50 PM
Wow Emil, that look overkill, no ? You really have to go that crazy with AP's ?
#22 MvZ
MvZ
Posted 15 January 2013 - 06:58 PM
No, doesn't look overkill or crazy to me.
I found this works pretty well most of the time. I actually always use a scheme like this on Jupiter, and know of several others who use a similar scheme. Sometimes with smaller APs, sometimes with less and larger APs (noise blue channels). Sometimes I even add some extra small APs over shadows of a moon or on a moon itself , but I'm always sure that the feature is stable enough to handle that.
But most of the time something like this works well.
#23 ZuoZhao
ZuoZhao
Posted 16 January 2013 - 01:04 AM
HI,Emil.
I know how to avoid this align problem just as you pointed. I say that because when I face this problem then mean I cant get a nice result from them. I found for a pic,for example, if size 100 AP will give best detail,when I use 100 cause problem(like this I post,usually only part of edge show problem),I will ignore them.
AS2 work quite well.I use it chose best video and later stack.Of course,if it can make a precise stack from bad seeing video,that not bad.
If you still want to get this video,I will send to you.I just got your post before I del it. unfortunately,the file large as usually.
#24 MvZ
MvZ
Posted 16 January 2013 - 05:45 AM
Ok, I understand.
I have send you a PM with details regarding the video.
#25 CanaryMax
CanaryMax
  • Loc: Gran Canaria, Spain
Posted 16 January 2013 - 10:45 AM
Hello:
Magnificent images with excellent detail.
Regards
Maximo
