Vixen Porta II head - 3/8" bolt?
6 replies to this topic
#1 Thomas Karpf
Thomas Karpf
  • Loc: Newington, CT
Posted 10 January 2013 - 10:57 AM
Will a Vixen Porta II head attach directly to a tripod with a 3/8" bolt? I already have a very solid tripod and don't really want/need another.
Thanks.
#2 Agatha
Agatha
  • Loc: Coulee Region, Wisconsin
Posted 10 January 2013 - 12:29 PM
Tom,
Yes, it should work. Depending on the top surface of your tripod, make sure that there is plenty of bolt threads that turn into the Porta base. Also, it is always a good thing to make sure all threads are clean of any metal debris, etc. I always like to put a hint of grease on clean threads also. It spins easier and pulls tighter easier and will even help protect threads. I like at least 4 full turns of a bolt into a mount head. It simply gives more holding power and less likely to strip the threads. And if you have a spare 3/8-16 bolt just by itself, do hand thread that into the Porta first just to make sure threads are good.
Best, Linda B.
#3 Thomas Karpf
Thomas Karpf
Posted 10 January 2013 - 12:52 PM
Linda,
Excellent. Thank you. Spending an additional $80 for a tripod that I don't need seemed silly.
#4 DavidNealMinnick
DavidNealMinnick
Posted 10 January 2013 - 10:14 PM
The Porta utilizes M10-1.5 threading.
#5 Agatha
Agatha
Posted 11 January 2013 - 04:28 AM
Tom,
Oh dear. :crazy: David is absolutely right. I just seemed to remember the number 3/8 being thrown around when the Porta II came out. I liked my original Porta so much I purchased another one (Porta II). I've never had it on a different tripod. So, just now at 3:30 in the morning :), I went and removed the head and checked the threads. Yes indeed. Definitely 10mm.
So, Tom, if possible, do change your tripod mount bolt to a 10mm X 1.5
A 3/8 will fit BUT it will be loose. The 10mm is correct and a proper fit.
Sorry for the confusion.
Best, Linda B.
#6 Agatha
Agatha
Posted 11 January 2013 - 04:38 AM
David,
Thank you for making the correction. I'm usually very particular with bolt threads, etc. I just went by what I remember hearing.
I still am surprised that the Tak Teegul uses a 3/8. At least, that is how it is described. A good reason to always check. :)
Thanks again.
Best, Linda B.
#7 Thomas Karpf
Thomas Karpf
Posted 11 January 2013 - 07:24 AM
David and Linda,
Thanks for the information.
