Meade Series 5000, 2 Inch Diagonal
4 replies to this topic
#1 Duplin
Duplin
  • Loc: Eastern North Carolina
Posted 11 January 2013 - 08:10 PM
Does anyone know if the Meade Series 5000 2" Diagonal with SCT Adapter will fit an LX5/2080?
I did a search both here and on the Meade website, but I can't find this specific info. Meade.com states that it will fit LT, LS, LX90 and LX200 series, but doesn't mention other models. I really don't want to spend $149 without knowing for sure this will fit my 'scope.
Thanks for your time.
#2 Rick Woods
Rick Woods
  • Loc: Inner Solar System
Posted 12 January 2013 - 01:06 AM
This is from the hip, but: I suspect it will. The SCT back thread has been the same for a *long* time. I have a '73 C8, and my Meade f/6.3 focal reducer fits right on, as does my generic 1.25" visual back.
But, I don't know for sure. Make sure you can return it, if it doesn't work.
#3 Duplin
Duplin
Posted 12 January 2013 - 10:08 AM
Thank you, Rick. I emailed High Point Scientific, they said I could return it for a full refund if it didn't fit...so I guess I'll get one.
Have a good day...
#4 REC
REC
  • Loc: NC
Posted 15 January 2013 - 12:56 PM
It should come with a SCT screw on adapter which is pretty standard. You then slip the diagonal into it with two set screws. FYI...the adapter comes in two parts. I use the shorter tube to avoid hitting the bottom of the base with mine.
#5 Duplin
Duplin
Posted 15 January 2013 - 06:28 PM
Thank you for the info.
