Filter wheels
2 replies to this topic
#1 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 11 January 2013 - 08:51 PM
Topic lifted from the Eyepiece forum discussion between me and Mike Sarkikos
John,
Yes, I could see the advantage to a permanent set of ersatz 2" eyepieces if I never used a filter wheel or binoviewer. But I have two filter wheels: one loaded with filters for the planets, another with filters for DSO. The planet filter-wheel sees much sky time at home - often stacked with a binoviewer!
The DSO filter-wheel is great at my dark site to see immediately the effect of different filters on bright nebulae or to switch between an empty slot and an O-III to bag planetaries. Often I've seen veteran observers spend quite a bit of time using my filter wheel to see how nebulae appear with the different DSO filters: broadband, UHC, O-III, H-Beta and an empty slot. Evidently it is a very convenient and practical gizmo that provides immediate feedback. Much better than having to screw filters on and off an eyepiece in the dark. :p
:grin:
Hey Mike, my 5 position filter wheel came today. I picked the 1.25" version to see how I fair with this before I think about a 2 inch one.
A couple of questions
1) the screwing eye piece adapter has a single set screw to hold the eye eject In place. I'm not happy with digging screw gouges in my eye piece barrels. How do you approach problem?
2) do you have a 2 inch wheel as well? If so, when/why do you pick one or the other?
3) this Orion model is sturdy, and then fittings are tight. Would you select a different model from another vendor if you were to do again?
#2 Fred1
Fred1
  • Loc: close to the inner rim of the Orion Spur, about halfway along its length.
Posted 12 January 2013 - 09:52 AM
Replaced mine with a nylon screw. But I forget what thread it is. Just bring the stock screw to a hardware store. Buy several white ones if they have them. They're easier to see in the dark.
#3 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 12 January 2013 - 01:56 PM
Now, that's a great idea! Thanks Fred, perfect! I can also use that on the visual back of my C6 :-)
