Atlas Grind
4 replies to this topic
#1 ponz
ponz
  • Loc: Kansas City, MO
Posted 12 January 2013 - 12:12 PM
I'm playing around, inside, with my new setup.
When the Atlas Mount first begins and at the very end of slewing there is a slight grinding sound; otherwise it sounds fine.
Normal??
Ponz
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 12 January 2013 - 04:37 PM
Normal??
Ponz
Yep. I hear that right at the beginning and the end and almost nothing in between.
#3 astro_baby
astro_baby
  • Loc: United Kingdom
Posted 12 January 2013 - 05:37 PM
Its actually not gears grinding but the resonance from the motor. Nothing to worry about. They all do it.
#4 ponz
ponz
Posted 13 January 2013 - 07:52 PM
Thanks guys - I was worried there for a minute!
Ponz
#5 Steve Drapak
Steve Drapak
  • Loc: Toronto, Canada
Posted 13 January 2013 - 07:56 PM
Mine doesn't :-) But it did develop it before. Check the net for instructions on adjusting the housing around the worm gear. It may need a slight tightening, not a major job. Check also if you can jiggle your mount in Dec or RA while the clutches are engaged, there should be virtually no wiggle. Your mount should just be making a smooth whirring noise when it slews.
