Celestron to meade wedge adaptor needed
6 replies to this topic
#1 highkamp
highkamp
Posted 12 January 2013 - 03:45 PM
I have looked around and cant seem to locate any kind of diy mod or prefabed adaptor to allow a celestron base (older 90's era) to mount to a meade eqt. lx200 style wedge. I know the bolt patterns are different between meade and celestron bases but Im sure this adaptation has been done many times.
I have a celestar 8 that I want to adapt to mount on my meade super HD wedge that my LX200 12 is used for.
#2 Sniemiec
Sniemiec
  • Loc: Johannesburg, South Africa
Posted 12 January 2013 - 04:51 PM
I had a similar need. I wanted to mount my Nexstar SE8 onto a Meade wedge from the early '80s. The Meade tripod and wedge are built like a tank! Very solid.
A quick trip to my local engineering shop resulted in a solid billet of aluminum cut and drilled to perfection. And cheap!
My recommendation after thorough googling. Find a local engineering shop and take the OTA and mount along.
#3 orion61
orion61
  • Loc: Birthplace James T Kirk
Posted 13 January 2013 - 10:31 AM
You can do what I did,
Make a template of the bolt holes from the bottom of your scope, mark it on the wedge face plate and drill new holes.
It works fine. Watch the back side depending which wedge you have, there may be ribs in the way.
good luck!!
#4 Geo.
Geo.
  • Loc: Upstate NY
Posted 13 January 2013 - 01:26 PM
Here's a measured drawing of the Celestron base pattern.
#5 cn register 5
cn register 5
Posted 13 January 2013 - 03:46 PM
My Astro society replaced an LX200 with a CPC-1100 and needed to fit it to the existing Superwedge. It needs a spacer to allow the wider base to overlap the wedge sides. I got a couple of extra holes drilled in the base and one of the other astro society members made some spacers with threaded rods on each end. This works beautifully.
Chris
#6 orion61
orion61
Posted 13 January 2013 - 08:37 PM
You drilled the base of the scope? or the wedge?
#7 cn register 5
cn register 5
Posted 14 January 2013 - 12:28 AM
The wedge. This wedge has a flat plate so it was easy to mark it out and get my next door neighbour to drill it out. (He makes model steam engines).
Chris
