Edmund model 4004 CL scope
46 replies to this topic
#1 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 05:53 PM
finally went and picked this up.
this thing is so cool looking.
needs some minor work and a few knobs but both drives work
and that joystick is neat also.
here are a few pictures.
ignore that unitron in the background your better off
with a 60mm f/11. :roflmao:
#2 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 05:54 PM
all the knobs are not the same.
#3 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 05:55 PM
some rusty bolts i think easily replaced with chrome.
#4 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 05:56 PM
nice photographic focuser.
i think this was a expensive option.
#5 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 05:57 PM
looks like the first version
#6 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 05:58 PM
who made the optics on this
#7 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 05:59 PM
drive pic_1
#8 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 06:00 PM
drive _2
#9 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 06:01 PM
mirror and cell
#10 mustgobigger
mustgobigger
  • Loc: Michigan
controller
#11 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 06:04 PM
funky looking secondary...yea its raining so no first light
tonight.
#12 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 06:06 PM
caps...my bottom one has a small piece missing.
#13 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 06:10 PM
see that thing on far right....homemade red light you stick
in the ground and connect to a battery...looks like an old running light.
#14 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 06:12 PM
needs new plastic knobs here also.
#15 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 06:15 PM
anyone know if the red levelers were standard on these.
have not seen pictures anywhere like them
#16 starman876
starman876
  • Loc: VA
Posted 13 January 2013 - 07:21 PM
Nice scope Brian. You are lucky these great scopes pop up around you. :bow: :bow: :bow: :bow:
#17 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 07:45 PM
i think this one is worthy of a restore job.
going to give it a first light run before i do anything.
well.... maybe order some knobs and bolts.
my wife loves it...says it looks like its coming in for a landing... :foreheadslap:
#18 starman876
starman876
  • Loc: VA
Posted 13 January 2013 - 07:47 PM
When the scope gets approval from the better half you have a winner.
#19 starman876
starman876
  • Loc: VA
Posted 13 January 2013 - 07:49 PM
what Unitron in the background. Please, let's see a picture of that also. I hope it is one of those folded refractors. They are great.
#20 apfever
apfever
  • Loc: Colorado
Posted 13 January 2013 - 07:53 PM
Brian,
I just checked 5 sets of legs (15 legs) and none have those levelers. I've nevr seen them before. My guess is that they are home spun. I have one set that has one leveler screw for fine alt adjusment, most sets have nothing, and one set has a full array of large swivel casters. That caster set is from an 8" that came directly from Joseph Cocozza's work, through his family, to me. These seem to get modified with custom levelers and casters. The end castings are well set up for that.
Look inside the OTA and see if there are only two holes for the bolts that hold that OAG focuser on. If there are only those bolt holes, and none other for a different focuser, then you have a rare factory original indeed. And I hate using the word 'rare'. I think it's overly abused.
Edit: Ahh yes, you have the earlier version OAG. I'm not sure how that one was mounted. The newer ones only had two bolts.
#21 actionhac
actionhac
  • Loc: Seattle
Posted 13 January 2013 - 07:57 PM
I've always thought those were the coolest looking scopes.
Very expensive in their day.
Can't wait for your report on the spider Brian. Probably not much in the way of diffraction spikes as thin as those vanes are.
How does the foucuser work? does it rotate or split the light cone?
Robert
#22 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 08:22 PM
Focuser is definetely factory
ins talled...4 bolts but very nice fit.
focuser does rotate and also
2 prisms inside....this model has all
The bells and whistles.
well built ...im going to find a ring
To fit tube for rotating.
#23 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 08:26 PM
Also the primary looks exceptional.
Covers did their job
#24 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 13 January 2013 - 08:28 PM
Hard to believe this is technology
From 35 years ago.
#25 apfever
apfever
  • Loc: Colorado
Posted 13 January 2013 - 08:45 PM
You got a great deal on this scope. The condition is admirable. I think these are unique looking scopes that really sepperate from the standard mold. One thing about them is the foot print. They have a HUGE spread over floor space.
Check the 8 pads (4 on each ring) that directly contact the OTA to hold it in the cradle. These might be bare cork. Felt, in good condition, on each pad can let the tube rotate by backing off the tension screws. The screws push on a metal bar that has pads attached. Check the lower fixed pads to make sure they hold the OTA off the metal cradle. These are built up with cork 'blocks' and rest down into a groove on the cradle end rig. Its easy to grind the OTA into the rings at this location if you rotate the tube.
Nice find. Glad you got it.
