Which is the least noisiest of these telescopes?
41 replies to this topic
#26 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 16 January 2013 - 08:44 AM
Dude, you have some picky neighbors. I can fire up my Harley at 2 AM and no body cares....
I doubt that! How do you know that no one cares? Just because they haven't said anything doesn't mean they don't care.
Kudos to the OP who is a good enough neighbor to care about 'his' neighbors.
#27 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 16 January 2013 - 10:04 AM
I don't know about the Orions, but I would say that the CGE and CGEM are probably the most quiet. However, the key is in the adjustment. The CGE and CGEM are relatively easy to adjust to make more quiet whereas the Nexstar and CPC are more difficult. The LXD75 is just plain noisy.
#28 gaz-in
gaz-in
Posted 16 January 2013 - 05:47 PM
The older Nexstar GPS and Nexstar 8i/5i mounts that were made in the US are MUCH MUCH quieter than the comparable Celestron CPC and Nexstar 8se. Plus the sound they make is (to me) much more pleasant that the new ones.
I just got an iOptron Minitower and was amazed at how noisy it is. Nice mount.....just noisy!
#29 gaz-in
gaz-in
#30 gaz-in
gaz-in
#31 gaz-in
gaz-in
The older Nexstar GPS and Nexstar 8i/5i mounts that were made in the US are MUCH MUCH quieter than the comparable Celestron CPC and Nexstar 8se. Plus the sound they make is (to me) much more pleasant that the new ones. By far my favorite mounts....
P.S. The 8i/5i can be had with OTA for around $500 to $700. The Nexstar 8 GPS $800 to $1200. IMHO, the Nexstar 8 GPS is one of the best scope mount combinations ever built.
#32 Procyon
Procyon
  • Loc: North Eastern Canada
Posted 16 January 2013 - 07:24 PM
So I think it comes down to getting a new 9.25 with the VX mount (See below), a Sirius EQ-G mount + a 9.25 OTA, or a CGEM mount + a 9.25 OTA... Which would you choose, strictly on noise level? If they all have slow slew speeds, does it really matter?
WOW... this is interesting:
http://www.optcorp.c...px?pid=56-18756
Slew Speeds: Nine slew speeds, 4 deg/sec maximum
Was this just announced?
Sirius EQ-G
http://www.optcorp.c...?pid=11882&tb=2
I also found this noise review for the CGEM:
http://www.astronomi...-mount-40-lb...
Motor noise-
The mount has 9 speed settings (1 is slowest, 9 is fastest), and the servo motors on the unit are surprisingly quiet. They were completely inaudible until the 6th setting and then were only whisper audible. Starting with setting 7 the motors became clearly audible and by 9 they were equivalent to say a 9 volt drill on low speed settings. Not at all obnoxious nor anywhere near loud enough to disturb the neighbors during a late night outing, but loud enough you know it's working. So at tracking speeds the motors are completely inaudible and the only time they exhibit sound will be during slewing....
#33 Procyon
Procyon
Posted 16 January 2013 - 07:26 PM
By the way, can I slew at slower speeds or is that for tracking only?
#34 BPO
BPO
  • Loc: South Island, NZ
Posted 16 January 2013 - 07:46 PM
Of the amateur level EQ mounts I've used, the S-W EQ6/Orion Atlas is arguably the quietest, much more so than a Losmandy G-11.
The Takahashi EM-x00 mounts are also reasonably quiet, and definitely sound the coolest.
Every Meade and Celestron SCT mount was hideous, like marbles in a blender.
#35 EFT
EFT
  • Loc: Phoenix, AZ
Posted 16 January 2013 - 09:41 PM
Sirius EQ-G
Motor noise-
My vote would be for the CGEM with the C9.25. It will handle the load very well and can take advantage of the Custom Rate 9 (which applies to slewing) to quiet things down if necessary. The VX and the Sirius will almost undoubtably be more noisy and will be more loaded (or overloaded) with the C9.25.
#36 Pauls72
Pauls72
  • Loc: LaPorte, IN
Posted 17 January 2013 - 09:03 AM
An LXD75 will keep the the neighbors awake and wild life away. Tuning it up will help, but it still sounds like a coffee grinder.
My Atlas is dead quiet.
#37 groz
groz
  • Loc: Campbell River, BC
Posted 17 January 2013 - 03:05 PM
We have a few mounts here, and, have compared them against others over time at star parties.
The EQ6-Pro and HEQ5-Pro (atlas/sirius in orionspeak) are the quietest of the bunch. Our neighbors have never noticed them. The Tak NJP is a close second, altho the prior poster is correct, it sounds much 'cooler'.
Our EQ3 sounds like a coffee grinder.
But, with that said, all of our mounts are substantially quieter than the cg5 and ilk we have seen at various star parties. When those start up, there is no guessing that someone on the field is slewing a telescope. Same can be said of the goto dobs, no question at all when they are slewing.
We've also had them set up beside an AP900, and, in all honesty, I dont remember what it sounded like, so, it must have been reasonably quiet.
As a general rule of thumb, if the motors and gears are hidden behind plastic, it's going to sound like a coffee grinder, or worse. If they are hidden behind metal, it's going to be substantially quieter. This is pretty much an across the board trend.
#38 EFT
EFT
  • Loc: Phoenix, AZ
Posted 17 January 2013 - 05:04 PM
This is definitely true. The plastic motor housings are great at amplifying sound. Thin sheet metal housing will do the same. When the motors and spur gears are buried down inside the castings it definitely reduces the sound. A CG-5 can actually be quite quiet if you run it without the motor housing on it.
#39 rockethead26
rockethead26
  • Loc: Arizona, USA
Posted 17 January 2013 - 06:26 PM
I'd love to see some nice, trim after-market metal housings for the CG-5. Just a pipe dream ...
#40 frozen.kryo
frozen.kryo
  • Loc: East of the Sun, West of the Moon
Posted 17 January 2013 - 10:02 PM
I sprayed the insides of my CG5's motor housings with rubberized undercoating, and stuffed the open spaces with sound dampening material.
It did help dampen the resonance and 'muffle' the sound somewhat. It was still noisy at max slew though. :tonofbricks:
I don't think metal housings will help quiet down the CG5 much, if at all.
#41 FaronD
FaronD
  • Loc: Richmond Hill, Ontario
Posted 17 January 2013 - 10:38 PM
None of these packages are under $500.00. I would agree that the Eq6 is very very quiet, especially when the gear slop is removed.
Faron
I really dont like the idea of noise coming out of my mount-telescope, especially in the summer months because I dont want neighbors peaking at 2am and wondering what the heck is this guy doing??
Can someone tell me which of these telescopes would make the least noise when tracking or slewing? Which least noisy mount, for around 500$, used or new, would be a good buy for someone who wants to do mostly visual with an occasional deep sky astrophoto?
1- Nexstar 8SE
2- CPC 925
3- Meade LXD75 mount w/9.25
4- CGE-5 9.25
5- CGE-6 9.25
6- CGEM 9.25
7- Orion XX12GT
8- Orion XX14GT
PS> I read the LX75 has a Quiet Slew mode, do the others have that?
Thanks.
#42 rigel123
rigel123
  • Loc: SW Ohio
Posted 19 January 2013 - 10:56 AM
Since there were so many discussions about which mount is quiet and which were loud I thought I'd throw in a video of my Altas slewing and what I hear (or don't hear!)
http://youtu.be/61P_Zq2Dh-k
