Low Power EP for 127mm Mak
3 replies to this topic
#1 Eric63
Eric63
  • Loc: Ottawa, Ontario
Posted 15 January 2013 - 10:17 PM
I currently use a 2 inch 32mm 70 degree Titan as a low power eyepiece in my 127Mak. I love the view I get in this eyepiece and I can get approximately 1.5 degree FOV. I'm therfore wondering if a 38mm 70 degree eyepiece would also work, or is it too low for this scope. I have the SW 127Mak, which came with a 2 inch diagonal, however the visual back is less than 2 inches.
Thank you
Eric
#2 Ed Holland
Ed Holland
  • Loc: San Jose, CA and Oxford, UK
Posted 16 January 2013 - 01:42 PM
You'll get something, but there will be vignetting. I use a ~60° 35mm (1.25") as my lowest power EP on the 127. This has some vinetting, but you have to look for it - for casual observing it is not intrusive. It's most easily detected when looking at the out of focus diffraction pattern of a star. The rings will appear distorted/cut off as you move the scope to place the star at the edge of the field in the EP.
Can you give the setup a try before purchasing?
Ed
#3 Eric63
Eric63
Posted 16 January 2013 - 07:00 PM
Thank you Ed. I'm mostly a visual observer, and with my limited experience I have yet to recognise any vignetting. I think I will take your advice and see if I can try out a 38mm EP first. Right now I like the 1.5 degree FOV that I have with 32mm. I guess I'm just trying to get a bit more sky in my view :grin:
Eric
#4 Ed Holland
Ed Holland
Posted 16 January 2013 - 07:59 PM
I don't blame you for trying. Not until I tried to look at the Pleiades, did I realise what restricted field of view really meant. That said, I purchased the scope as a convenient means of planetary viewing and to satisfy a curiosity about catadioptric instrument designs. For these purposes, it has served very well indeed :)
Ed
