Jupiter 20130108 in SHENZHEN ; A warm night~
26 replies to this topic
#1 ZuoZhao
ZuoZhao
Posted 17 January 2013 - 09:59 AM
A warm night in winter. Seeing became good,I dont need to trill in cold wind. Let's take a warm Jupiter. Again,took the moons around Jupiter similar they original position.
#2 Rankinstudio
Rankinstudio
  • Loc: Southern UT
Posted 17 January 2013 - 11:23 AM
Beautiful.
#3 karlo
karlo
  • Loc: Yorkshire,UK, BLIGHTY !!
Posted 17 January 2013 - 02:52 PM
You are in a thread of pure gold at the moment- superb shot !!
#4 anemec
anemec
  • Loc: Oklahoma
Posted 17 January 2013 - 05:25 PM
Wonderful.
What is your processing routine, if you don't mind my asking? I have the ASI120MC and am curious how other people handle their post imaging processing.
#5 Tassydevil
Tassydevil
  • Loc: Tasmania, Australia
Posted 17 January 2013 - 06:42 PM
Very nice.
#6 azure1961p
azure1961p
  • Loc: Triton
Posted 17 January 2013 - 11:11 PM
What size scope? This is stunning.
Petr
#7 wenjha
wenjha
    Vendor
  • Loc: SuZhou China
Posted 18 January 2013 - 12:12 AM
Wow!I think I need to use ASI120MM instead of ASI120MC.Can't be lazy any more
#8 ZuoZhao
ZuoZhao
Posted 18 January 2013 - 05:04 AM
Wonderful.
It seem you need some basic articles. Maybe some can help you. I dont have a link in English.
My routine not an exception as usually. Capture>AS2>R6>JUPOS>PS But you need compare and try again and agin every step.
#9 ZuoZhao
ZuoZhao
Posted 18 January 2013 - 05:05 AM
Petr
I use a Skywatcher DOB10 GOTO
#10 ZuoZhao
ZuoZhao
Posted 18 January 2013 - 05:06 AM
Jupiter passed ...
#11 Ciarlotto
Ciarlotto
  • Loc: Mondragone - Italy
Posted 18 January 2013 - 05:14 AM
Hi, I see you use a Dob Goto (I've the SW 12" GoTo): I've noticed that my dobsonian isn't perfect in tracking objects (I make a perfect alignment) so I often have to adjuste the tracking by handset. Is your tracking sistem perfect or does it work not perfectly as mine?
... Your images are perfect!
#12 ZuoZhao
ZuoZhao
Posted 18 January 2013 - 06:13 AM
OH...yes. We have the same system. It cant track perfect. So I must stay with computer all the time and correct object to center of screen. :bawling:
And I must use a capture screen much wider than object.For example,800X640 for a 430X430 Jupiter. I must keep some space let Jupiter run fron one side to other side.
unfortunately,a wider size ill limit the capture speed.For example,800X640 limit 50fps, and 640X560 will 60fps.
So...my work really hard.
#13 TorstenEdelmann
TorstenEdelmann
  • Loc: Landsberg, Germany
Posted 18 January 2013 - 06:19 AM
Fantastic image again.
Given the consistent superb seeing on your location you should consider going for a bigger scope.
Torsten
#14 Ciarlotto
Ciarlotto
Posted 18 January 2013 - 06:30 AM
Thank you very much for your simply explanation. I can understand how hard is the "backstage" of your images. It's just difficult to take a single movie to obtain a single B/W image: I dont' image the work you have to do to make an RGB composition! Now, Appreciate even more your images.
#15 Space Cowboy
Space Cowboy
  • Loc: Cheshire, UK
Posted 18 January 2013 - 09:29 AM
Superb detail again ZZ! As Torsten says a bigger scope would produce very special images in your location with that great seeing. Maybe a 14" Dob? :smirk:
#16 ZuoZhao
ZuoZhao
Posted 18 January 2013 - 11:02 AM
Torsten
Well... many thing must be considered. If I want to get presise tracking,a equatorial system must be. A big capacity EQ like Paramount will very expensive. Maybe, a DOB16 GOTO still a good choice.
#17 Mert
Mert
  • Loc: Spain, Pamplona
Posted 18 January 2013 - 11:10 AM
Just one question on the hard working side of imaging you
told us about!
What program do you use for imaging?
You could use Firecapture to do the Autoguiding for you,
it really works great.
Lately I did 3 hours imaging on a ROI of 320x320 with
4200 mm FL without even being at home!
All avi's had Jupiter perfectly centered!
Can't recommend it enough! :shrug:
#18 ZuoZhao
ZuoZhao
Posted 18 January 2013 - 11:20 AM
told us about!
I still use SharpCap. Firecapture not work on my capture PC(it work on my processing PC but). I dont know whether a DOB support autoguiding. It is work like deep sky autoguiding? May you can tell me more detail. If it can autoguiding to a DOB, a big DOB will be great choice!
#19 ZuoZhao
ZuoZhao
Posted 18 January 2013 - 12:14 PM
A simple question: autoguiding of Firecapture need a guiding telescope or not?
#20 TorstenEdelmann
TorstenEdelmann
Posted 18 January 2013 - 04:34 PM
There is no guiding scope needed for autoguiding in Firecapture. You need an ASCOM driver for your DOB and I'm not sure if the guiding interface would work with an AZ mount.
#21 Mert
Mert
Posted 18 January 2013 - 06:18 PM
If it is ASCOM Torsten, then guiding could work, but
I don't have a DOB to try that.
As far as I know, the centroid movement will be
contra-rested so the object should stay centered.
How is the interface with a PC going on this DOB?
#22 Ciarlotto
Ciarlotto
Posted 19 January 2013 - 05:06 AM
A few time ago, I found a software called "Dave solar system recorder": I never used it because for my ability it's "tricky", but it seems to be suitable for guiding SW Alt-Az tracking system in HI-res imaging ... It requests ascom platform but doesn't request a guide scope and I don't know if it is compatible with ASI cameras. Surely it is compatible with IS DMK21 camera. Do you Know it? If this software performs as it should promise, I think that it should be a great effort in order to make better SW Dob autotracking...
#23 Kokatha man
Kokatha man
Posted 19 January 2013 - 09:35 PM
.....thought I'd responded to this thread earlier ZZ, but I hadn't - another fine image from you!
#24 ZuoZhao
ZuoZhao
Posted 21 January 2013 - 06:20 AM
Thanks all. Now is a earlier one. GRS stiil on edge.
#25 ZuoZhao
ZuoZhao
Posted 21 January 2013 - 08:09 AM
I can control DOB10 with Stellarium.I think it will work. The bad news is ,FC dont work on my imaging PC. :foreheadslap:
