Power source question
7 replies to this topic
#1 mtw4518
mtw4518
  • Loc: Saint Michael MN
Posted 19 January 2013 - 11:13 AM
I was going to buy a larger power tank to run my scope and dew zapper, but after reading all the comments on here about using a jump starter, I will go that direction. My only concern is the DC outlets on the power tank are fused at 10 amps, but all the jump staters I have found are 15 amp. Is this something to be concerned about?
#2 Bob Griffiths
Bob Griffiths
    Getting Grouchy
  • Loc: Frederick Maryland
Posted 19 January 2013 - 11:47 AM
NO....
Bob G
#3 mtw4518
mtw4518
Posted 19 January 2013 - 12:06 PM
#4 Arthur Dent
Arthur Dent
    Galactic Hitch-Hiker
  • Loc: South Yorkshire, UK
Posted 19 January 2013 - 05:45 PM
To amplify Bob's answer,
No, the device will only draw as much current as it requires.
As long as it is 12V dc output, you should be fine.
Art Posted Image
#5 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 19 January 2013 - 05:57 PM
None of your equipment will draw anywhere near 10 amps so you're fine.
-Dan
#6 mtw4518
mtw4518
Posted 19 January 2013 - 06:59 PM
So, no worries of the power source sending more amps than needed? The fuse is so the equipment attatched doesnt overdraw power?
#7 Midnight Dan
Midnight Dan
Posted 19 January 2013 - 08:33 PM
Correct. The equipment only draws the current that it needs. A power supply cannot "send" more.
And yes, the fuse is there to protect the power supply, not the equipment that it is connected to. If the equipment were to develop a short circuit, it could start drawing hundreds of amps and, in the worst scenario, the battery could explode. The fuse prevents this from happening.
-Dan
#8 mtw4518
mtw4518
Posted 19 January 2013 - 08:58 PM
Thanks I understand now, it makes perfect sense
