50mm Guidescope stroke of luck
6 replies to this topic
#1 dandabson
dandabson
  • Loc: Dover, DE
Posted 20 January 2013 - 10:41 AM
So for a while I have been gathering pieces for a project guide scope. I was using a widefield 80mm with decent luck. I am only imaging with a 4.5 starblast imaging OTA and the guidescope was heavier and bulkier than the imaging tube. So, I purchased a used Bausch and Lomb 50mm finderscope with 3 point rings of the 'Mart'. Next came the new HP HD webcam I bought off ebay. I did the mods to the camera, removing excess plastic and lens, and tested it. I had an old 1.25 to 2 inch adapter sitting around. A lot of work with a metal file and it finally fit into the tube. I set it up on a tripod and attempted to get some video to align it to the imaging ota. I focused on the farthest point I could see away. A electricity pole box with a green LED light down the street. I focused and waited to give it a try at night. Well I set everything up and aligned the mount. I left the scope pointing at the last calibration star. I powered up the webcam expecting to see nothing, needing to adjust focus settings would take forever I thought. The window popped up on the laptop with a perfectly focused star. I slewed the scope over to M36 to try to image it. Sure enough the guidescope picked up a star. It guided perfectly for over 37 minutes. Not bad for something I cobbled together.
#2 CJK
CJK
  • Loc: Northeast TN
Posted 20 January 2013 - 01:34 PM
Nice work! :waytogo:
-- Chris
#3 microstar
microstar
  • Loc: British Columbia, Canada
Posted 20 January 2013 - 06:07 PM
I find a lot of the fun is putting together equipment and finding to my surprise it works!
...Keith
#4 Jaimo!
Jaimo!
  • Loc: Exit 135 / 40° North
Posted 21 January 2013 - 12:33 AM
Nice work! Nothing a little elbow grease and ingenuity can't solve!
Jaimo!
#5 StarStuff1
StarStuff1
  • Loc: South of the Mason-Dixon Line
Posted 22 January 2013 - 04:03 PM
There is a lot of pride (and it should be so!) in making a useful accessory for your self and it works so well!
#6 ZeroID
ZeroID
  • Loc: Auckland, New Zealand
Posted 22 January 2013 - 07:35 PM
My guidescope is a 50mm bino objective inside a cutoff Xerox Toner tube with a cheap plastic focusser assembly with an SPS880 webcam mounted into a hommade angle aluminium with rubber straps and adjusting knobs.
Works perfectly, 2 hour guides using PHD.
#7 Jaimo!
Jaimo!
Posted 22 January 2013 - 07:48 PM
You need to post a photo of that!
Jaimo!
