Azimuth clutch gets stuck
4 replies to this topic
#1 akulapanam
akulapanam
Posted 20 January 2013 - 01:38 PM
I was wondering if it was normal for the Azimuth clutch to get stuck in cold weather. I take the scope out with the clutch loose then tighten for the goto routine. However after about 4 or 5 hours after I turn my scope off I find that I can no longer release the clutch by hand. Usually by the next day I can release it again. I would obviously like to avoid moving it with the clutch stuck like this and I was wondering if this was normal or if there was some key to getting it loose.
#2 MikeBOKC
MikeBOKC
  • Loc: Oklahoma City, OK
Posted 20 January 2013 - 03:43 PM
I have had that happen a few times. I just GENTLY tap one of the clutch gripper ridges with a small hammer and it pops loose easily.
#3 Doc Bob
Doc Bob
  • Loc: Maryland, USA
Posted 20 January 2013 - 11:15 PM
I've also experienced this problem . . . did the same thing Mike suggested, and it worked. I have found that the clutch doesn't have to be ratcheted tight to work - actually on my scope I just lightly tighten the clutch; tracking is fine and it has not been stuck in 2 winters.
Bob
#4 Koen Dierckens
Koen Dierckens
  • Loc: Antwerp, Belgium
Posted 24 January 2013 - 01:56 PM
Happens to me too, but then the opposite way: if I tighten it when it is cold, I am unable to unlock it when it has warmed up. I guess it has something to do with thermal effects on the different components of the clutch. I always make sure the clutch is loosened when not in use. Best practice anyways.
#5 Doc Bob
Doc Bob
Posted 24 January 2013 - 06:42 PM
+1 Koen !
