Ioptron tripod
7 replies to this topic
#1 donjoy
donjoy
Posted 22 January 2013 - 11:58 AM
HI; I have a Ioptron telescope which works well the only problem I have is the hight of the tripod.It isn't high enough for observing unless I squat way down to look.Any body have any ideas? thanks Don
#2 Agatha
Agatha
  • Loc: Coulee Region, Wisconsin
Posted 22 January 2013 - 12:14 PM
Don,
I assume you are viewing while standing. Have you used or considered a viewing chair? Much more comfortable than squatting. :)
Best, Linda B.
#3 donjoy
donjoy
Posted 22 January 2013 - 12:21 PM
HI; thank you for writing.The tripod seems to be in a kind of nuetral zone.It's just like in a middle spot that is not a comfort zone and seems to need about 6" higher.the legs are a little unstable at full length.I wonder if anyone else has replaced the tripod with another one that fits the scope.
#4 frebie
frebie
    Chief assistant to the assistant chief
  • Loc: Neither here nor there.
Posted 22 January 2013 - 03:08 PM
iOptron has a mini-pier that adds 8" to the height of most of their tripods. Here's a link to the iOptron webpage:
http://www.ioptron.c...f1ba874-4bdc...
#5 donjoy
donjoy
Posted 23 January 2013 - 09:08 AM
Thank you frebie.I'll look into that.
#6 Spaced
Spaced
  • Loc: Tacoma, Washington, USA
Posted 23 January 2013 - 05:31 PM
Another low-tech solution: My woodworking wife made me some blocks out of 4" X 4"s, stabilized with little lateral 1 X 2" braces that extend a couple of inches off to the sides, to place under each of my tripod legs to raise the whole thing about 5".
#7 donjoy
donjoy
Posted 24 January 2013 - 05:06 PM
Thanks for the light.I do woodworking and i've thought of trying that so i'll check that out.I think i'm going to look for a sturdier tripod though I saw a tripod for a celestron but I can't be sure if it will fit the cube.It's the kind where the arm fits in like a semicircle.
#8 donjoy
donjoy
Posted 06 February 2013 - 09:12 AM
HI; I bought a celestron tripod and it looks like after a few changes it will work well.The tripod is for a one arm scope and i'll have to fill in the indentation where the arm mounts and put a round aluminum top on and it will be good to go.It is about 6" higher than the ioptron and has a level bubble like the ioptron and is much sturdier.Thank You for your help!!!!!.
