ASI120MM? Looks great but can it do 16 bit?
6 replies to this topic
#1 R Botero
R Botero
  • Loc: Kent, England
Posted 25 January 2013 - 05:24 AM
As per the title. Currently have a PGR Chameleon for solar and may start doing some planetary imaging.
The frame rate on the Chameleon is not the best but can still do it.
The recent images and specs of the ASI120MM look amazing :cool: apart from the bit rate. What other camera in the same price bracket can do 16 bit? :help:
#2 MvZ
MvZ
  • Loc: The Netherlands
Posted 25 January 2013 - 05:45 AM
(*Yay for another 16-bit thread!)
No it can't do 16-bit. But are you sure you really need it? What kind of gain levels do you normally use when imaging the sun?
I'm not familiar with any similarly priced camera's performing as well as the ASI120MM to be honest.
#3 dobsoscope
dobsoscope
Posted 25 January 2013 - 08:15 AM
What is the 16-bit advantage if I may ask as I cannot find any answers online.?
#4 dobsoscope
dobsoscope
Posted 25 January 2013 - 08:22 AM
OK Sort of found the answer here http://www.cloudynig...5641475/Main...
#5 R Botero
R Botero
Posted 25 January 2013 - 09:17 AM
Hi Emil
Thank you for replying and for AS! :bow: I use it regularly but I would like it to to handle 16bit files (.SER)!... ;)
I do use some gain in my Ha imaging but you are correct that little is needed if any. I may be mistaken here but I do tend to get better results from 16bit streams than from 8bit streams after using the same processing routines in PS C6. It may be my imagination but I do think I end up with more artifacts in the 8bit image.
In any case, my question was about similarly priced cameras to the PGR Chameleon and ASI120MM that were 16bit. Are there any?
#6 MvZ
MvZ
Posted 25 January 2013 - 12:23 PM
It can handle them. At least the last time I checked (which I admit is a long time ago!). If it doesn't work for you, please send me a small sample of a 16-bit SER file so I can have a look for you.
#7 R Botero
R Botero
Posted 25 January 2013 - 12:43 PM
I apologise in advance if this should have worked for me. I will check as soon as I get to my imaging laptop. No doubt you are right! :o
