Mild barlow for use with Leica 20-60x zoom?
9 replies to this topic
#1 Aquarist
Aquarist
  • Loc: Illinois
Posted 26 January 2013 - 08:55 AM
Any recommendations for a mild barlow with the Leica 20-60x zoom? Thanks for any ideas/recommendations.
#2 johnnyha
johnnyha
  • Loc: Austin, TX
Posted 26 January 2013 - 03:25 PM
You can screw the lens element of a Barcon onto the adapter, I dunno about the 20-60X zoom but in the ASPH this yields around 1.5X I believe. Only potential problem is the threads might not match exactly - mine don't.
A GSO barlow element would be a less expensive solution, I imagine it yields similar magnification.
#3 Doug Culbertson
Doug Culbertson
Posted 26 January 2013 - 03:38 PM
I use the Antares 1.6x barlow, which actually yields around 1.54x or so. I find it to be an excellent barlow, and you can add a 2" extension to get 2x.
#4 Aquarist
Aquarist
  • Loc: Illinois
Posted 26 January 2013 - 03:56 PM
Actually I have the ASPH. I thought the Astro-Physics Barcon was discontinued and replaced with their 2" Advanced Convertible Barlow. Is that likely to be threaded for the ASPH? 1.5x is really what I would like.
#5 johnnyha
johnnyha
  • Loc: Austin, TX
Posted 26 January 2013 - 05:05 PM
The ASPH is not 20-60X, it's 25-50X.
I have an older Barcon which has 48mm threads but they do not match the pitch of the 48mm threads on my Leica Adapter, I can only screw it in a couple turns. I imagine the new Advanced Barcon would be the same. This is the fault of the APM Leica adapter not the Barcon.
I also have an Antares 1.6X barlow as Doug mentioned and it works really well with the Leica ASPH zoom.
#6 Aquarist
Aquarist
  • Loc: Illinois
Posted 26 January 2013 - 05:45 PM
Yes, you are correct, my cutting and pasting was poorly done. I guess I will go with the Antares since that is about what I was looking to obtain.
#7 johnnyha
johnnyha
  • Loc: Austin, TX
Posted 26 January 2013 - 05:54 PM
Good choice. I have found the Antares 1.6X barlow to be an extremely versatile 2" barlow - low profile, inexpensive, and excellent quality - it seems to work well with everything. :cool:
#8 andydj5xp
andydj5xp
  • Loc: 52.269 N/10.571 E
Posted 27 January 2013 - 02:55 AM
Despite the title of this thread Leica ASPH in a slow Newt the discussion mainly deals with different configurations for barlowing the Leica ASPH. In case you haven't seen it have a close look.
Andreas
#9 Aquarist
Aquarist
  • Loc: Illinois
Posted 27 January 2013 - 09:05 AM
I have not seen it but will check it out. Thanks!
#10 Aquarist
Aquarist
  • Loc: Illinois
Posted 27 January 2013 - 09:53 AM
Excellent information. Thanks Andreas!!!
