Best eyepiece dew heaters??
3 replies to this topic
#1 Daniel Guzas
Daniel Guzas
  • Loc: Bethlehem NH/ Boston MA
Posted 26 January 2013 - 01:00 PM
I have searched a bit on this forum and is seems that the Dew Not heaters are highly recommended. However some believe the Kendrick heaters are better.
I have a binoviewer with a couple of ES eyepieces that I have to add some sort of heating because of the cold. I currently have a Kendrick controller with 2 ports ( one for my wood wonders box dew heaters) and one spare available to possibly hook up a pair of eyepiece heaters.
So my question is... Can I use the Dew Not heaters with this controller or do they have to be Kendrick heaters?
Also is one necessarily better than the other? The Kendrick seem much more expensive. Am I getting more for the added cost?
Any advice would be helpful.
#2 GlennLeDrew
GlennLeDrew
Posted 26 January 2013 - 01:12 PM
All these heaters run on 12VDC, and so are essentially compatible with the competition's gear. There may be minor differences in resistance between heaters of a given 'format', and hence a difference in heat output, but this should be of no real concern at all.
#3 Fred1
Fred1
  • Loc: close to the inner rim of the Orion Spur, about halfway along its length.
Posted 26 January 2013 - 01:23 PM
The Kendricks are built better. They have cables and heating elements that are much more pliable in the cold and better RCA connectors. If you observe in sub-freezing temps and into the teens, I'd say go with the Kendricks, otherwise the Dew-Nots are fine. I have both. However, DewNot will do custom lengths and widths, if that's important.
#4 ausastronomer
ausastronomer
  • Loc: Kiama NSW (Australia)
Posted 26 January 2013 - 08:50 PM
I have locked this thread as it is duplicated. It can be found here, in the equipment forum
John B
